Question about Sanyo DP42746 42 in. Plasma Television
Green Screen The screen on my Plasma TV suddenly turned all green even though I can still hear the sound. Has my TV died?
  • 71 Answers
Press the menu button select the last option white pattern and turn it on. keep it on for atleast a day.
Posted on Mar 08, 2009
Panasonic Plasma 50 TH-P50U30A blacked out with no sound
Appears to be a power supply issue with everything being so dead.
Jan 22, 2017 | Panasonic Televison & Video
I have a JVC pd-42n30 plasma televsion. The screen will not come on even though the light on the TV is green. There is sound though. When you switch the tv on it makes the usually sound but multiple t
Some thing short circuit inside it. It will be not be easy to detect such faults; even for an experienced service technician. The click you hear from inside, is the symptom of short circuited component/s. It will be best to contact the authorized service centre in this case; especially to Plasma displays. It sounds that any sustain board has the fault. But to detect which one; is the main case. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 06, 2014 | Televison & Video
TV TURNS ON BUT NO DISPLAY AT ALL.
do a reset by manually holding down the power button, sometimes that works
Jan 28, 2014 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
My Zenith plasma TV blinks green 4 times then goes red, No picture. None of the Capasitors are blown.
I had AWFUL customer service. (Sherry is DREADFUL her # is 1-877-543-8325 she is in"executive services". Ask to speak to her directly...if you would like ZERO help.)
They WILL NOT extend the warranty, even though they know there is a defect with this AND other models. Zenith name on the front...LG guts in the inside.
Ours turns on, screen black and then clicks three times and then turns back off.
Jul 13, 2012 | Zenith Z50PX2D 50 in. Plasma HDTV
Horizontal half black screen, sound is still there
A plasma screen uses thousands of tiny fluorescent bulbs in different colours (red blue and green) to produce a picture. Just like standard house hold fluro lamps, these tiny bulbs use starters to turn them on and off. As there are so many bulbs in the panel and therefore starters, the panel has a number of "starter controllers". These controllers can control anywhere from a quarter up to half of the screen. If a controller dies, it takes out it's segment of the screen. Unfortunately, it sounds as if this is what has happened in the case of your LG - this is also common in NEC and Fujitsu panels. Althought these controllers can be fixed, it usually takes more time and money than it's worth- unless you have it under warranty in which case the manufacturer will just replace it. Sorry top be the bearer of bad news. hope it helps
Jul 06, 2009 | LG 42PC3D 42 in. Plasma Television
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Vizio P50HDM No Picture/No Sound
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Screen goes completely green and ''dotty''. Sound still there.
It is dying a slow and painful *****. Time to retire the set after all those years of faithful service and move on.
Sep 09, 2017 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Tv goes black and the green light stays on and the sound also works
Try Shining a bright light at the screen. can you see any images on the screen? If you can, then the backlight on the tv has gone, and can be replaced. If you cant then it may be a fault with the inverror (power) board on the TV
Dec 26, 2006 | Maxent MX-42HPM20 42 in. Plasma HDTV
Sanyo DP42746 42 in. Plasma Television Logo
155 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
