Question about Cameras
How do i instal drivers and applications with windows vista
    Champion:
  • 225 Answers
Download the latest drivers from the camera maker's web site.
Posted on Nov 13, 2008
I have installed window 7 ultimate on my machine and have fwt huawei wireless modem,but i have struggled to find driver that i can use with the modem
Run application setup.exe on virtual CD created by Huawei Modem. If you installing this application, it will also installing drivers.
Aug 07, 2011 | Microsoft Windows Vista Ultimate Edition
Tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 | Computers & Internet
This application has failed to start because d3d10.dll was not found. and error 8003002: could not start application sky orb. the requested render path could not be loaded.
Download DirectX 10 and install. SkyORB 3D
  • Operating Systems: Windows Vista, Windows 7
  • Requirements: 29.6MB hard drive space to download, 52.3MB installed; DirectX 10 required (Windows Vista or 7 only); updated graphics drivers recommended
  • Dec 31, 2010 | realtech VR SkyORB 2010
    DRIVERS FOR WINDOWS VISTA OF DFM-562lS/CH
    Go here
    This is dlinks ftp access to your modems drivers. Click on the applicable driver (32 bit vista drivers most likely unless you have an Athlon 64 or something similar). Open the zip file up, extract it to a folder on your desktop and run the setup application, which will install your drivers. Will probably have to reset the computer afterwards.
    Hope this helps,
    Bill
    Oct 04, 2009 | D-Link DFM 562IS (DFM-562IS) Modem
    C language is not running in full screen mode
    Windows Vista takes away a lot of support and convenience for the sheer attractive of flashy user interface. One major feature is the ability of open full screen window for command prompt shell in Windows Vista. When you attempt open or run DOS .com applications, .bat batch scripts or games that relies on command prompt, and including cmd.exe itself, you will encounter the following error message:
    This system does not support fullscreen mode. Choose “Close” to terminate the application.
    The lack of support for full screen DOS command prompt in Windows Vista is a big annoyance especially for those who still playing games for DOS and Windows 3.1/9x era, use legacy software such as WPDOS or programmers who frequently switch to command prompt to use DOS based programming language such as PASCAL.
    There is no simple solution to this no support for full screen window in Windows Vista. In almost all possible workarounds, you are almost guaranteed that your Vista will be broken in some way, at least on the part on Windows Aero. You will lose the nice Aero Glass interface if you attempt any of these trick, plus other unknown side effects.
    Workaround to Run or Open Full Screen Window Mode
    Workaround 1: Use XDDM driver instead of WDDM driver for video graphics adapter
    In another word, install the Windows XP video card driver for use in Vista. If the video graphics card hardware supports Windows XP driver, you can download the Windows XP driver for your video hardware and install it under Vista. However, be warned that using XP driver on display adapter may crash your Vista system randomly, so save your works before proceeding and use with care.
    Note: This solution has been recommended by Microsoft in KB926657.
    To install a Windows XP video driver under Vista, just follow the procedure listed in the guide below. The steps should work for both NVIDIA and ATI video graphics accelerator card.
    Download the Windows XP driver installer for your graphics card from NVIDIA or ATI. Run the installation setup program just downloaded. Confirm any User Account Control permission warning when prompted. The installer will first extract and unpack the files required by installation to proceed to a folder/directory. Note down the path to the folder. For ATI, the folder for these installation files usually located in a directory with a name that resembles C:\ATI\SUPPORT\7-5_xp_dd_46743\Driver or C:\ATI\SUPPORT\7-5_xp_dd_ccc_wdm_46743\Driver, with the only different been the number to indicate the version and build number of the driver
    Jul 31, 2009 | Computers & Internet
    Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
    My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
    Fast Forward:
    Two PC crashes later, July 2009. Using Win Vista Home Premium
    LOST, important WinWord document file, only a hard copy available.
    I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
    It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
    Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
    Printer is not recognized by some programs for some reason.
    generally say the printer driver install no problem, but why some application can not seen as a selectable printer device? you may try
    1) same application might not be compatible 100% to Vista, when you open a PDF file and click print you can not see your printer device model on first print screen.
    2) try to change printer driver or utility and application installation sequence.
    3) you may try install fox reader for Vista, see what happen to print
    Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Instalation problum
    PLEASE CHECK THE PRODUCT WILL SUPPORT FOR WINDOWS VISTA BECAUSE SOME PRODUCT WILL NOT SUPPORT FOR WINDOWS VISTA ...PLEASE DOWNLOAD DRIVERS FOR SUPPORTING WINDOWS VISTA...
    Apr 30, 2008 | Computers & Internet
    HP DesignJet 450c driver for windows vista
    THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
    Feb 20, 2008 | HP DesignJet 450c InkJet Printer
    MP160 unknown device error in Vista
    How do I install the downloaded driver and software?
    If you have upgraded to Windows Vista™ from another Windows version or have installed drivers and application software from a previous Windows version, the previous driver and application software must be uninstalled prior to installing the Windows Vista™ drivers and application programs. Uninstallation instructions
    Prior to installing the driver software, power off the printer and do not turn it back on until instructed to do so during the installation.
    Vista Software can be found here
    http://software.canon-europe.com/products/0010392.asp
    Select Vista for the OS
    Select English
    Click Submit
    Download software and drivers applicable to
    Windows Vista 32 bit.
    Install the downloaded software
    Dec 18, 2007 | Canon PIXMA MP160 All-In-One InkJet...
    Cameras Logo
    111 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
