Question about Microsoft LifeCam VX-1000 Webcam
New cam and it doesen't go..where is the problem??
I've instal my cam but then it dosn't go so i
swapped such the cam... jet i've install the cam by internet but it doesen't go...where is the problem???
  • tss22yhcm Nov 15, 2008
    yes I have the same problem. I tried to fix it many time but it did not work. The screen goes green. pls help. thanks. Tess
    President:
  • 8,637 Answers
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Feb 01, 2009
Would i need a 650cfm carb after installing a high rise intake manifold?
It's all jet size and powervalve, also make sure your float level is sorted, then just swap jets eg bigger/smaller, and powervalve to suit timing
Feb 22, 2015 | Holley 0 80552 650 Cfm Four Barrel...
I did a engine swap with a used engine i ve tryed everything but it wont start no spark i changed the cam and crank sensor but still nothing any ideras
Read this installation guide for carrying out any type of car engine's installation step by step with expert guidance here. The entire process is carried out in a simple and easy to follow procedure at
http://www.hiperformer.com/installation-guide.html
Here you will guidance from experts who have 37 years experience in the field.
Dec 09, 2012 | 2000 Land Rover Range Rover
Toshiba satellite l505-s5971 web cam dosn work after i install win7
Go to toshiba.com and download the updated drivers for Win7. Make sure you get either 32 or 64bit OS drivers.
Jan 30, 2011 | Computers & Internet
I've got a Screamin Eagle 29440-99D Air Cleaner that I'd like to install on my 2003 FLHTPI. I didn't get the instructions when I bought it on Ebay. It's new with all the parts, except the instructions and...
In this situation I'd just go ahead and fit the air filter simply because the major change required after fitting it would be to the jetting(not the EMC).
Then when they dyno tune it they will probably also use an infra-red gas analysis unit to check the jetting, as again the jetting will be affected by the different cams or exhaust you are having fitted.
Regards
Dec 11, 2009 | 2005 Harley Davidson FLHTC - FLHTCI...
No low end response and cam (andrews n4) will not kick in until 4000rpm. Cv carb with dyno jet kit installed. Slow jet is 42, 170main and eclip is on 3rd groove.
look at new spark plug for colour after running 1/3 thottle
if clean or carbon
i susspect you have spark curve issues (timing) if changed the orginale cam shafts profiles
Aug 17, 2009 | Harley Davidson XL Sportster 883...
Webcam cannot be located in my compaq CQ 40 -108TU laptop
the driver was installed
u need a application to run
download hp website
sp37849
cyberlink youcam
and install it
Jan 18, 2009 | Compaq AVC00-AA Webcam
Plzzzz help me =[
Firstly Logitech cams are plug and play, what happens when you plug it into the USB port?
Oct 18, 2008 | Logitech QuickCam Messenger Web Camera
Web Cam in use by another application.
you remove all the software installed by browsing controll pannel>system>device manager and disconnect the w/cam restart the system then connect the cam the system wii detct the cam then u install the software again it will work.
Sep 03, 2008 | Xirlink Promax Webcam
Microsoft LifeCam VX-1000 Webcam Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
