Question about Liquid Video L17LCD2 17" Flat Panel LCD Monitor
Brief flickers on a Liquid Video L17LCD2 monitor
I replaced both the C922 and C924 capacitors with new 1000 and 470 uF,35-volt units, making sure I got the polarity right. Still getting the same on/off behavior -- the desktop image appears only momentarily (less than one second), the monitor light goeso ff for about five seconds, then comes back on and the (very) brief image appears and the light goes out again. It keeps repeating. Some of the comments suggest it could be problems with the high voltage part of the inverter board, or maybe the little backlight bulbs. Sounds like I may need a new board. Do you know if I can buy one from Liquid Video? -- or do you have any suggestions for other things to try first?
    Problem Solver:
  • 6 Answers
I did the same thing. I fried the smaller capacitor instantly so I reinstalled the old one & it works fine now. Any buldging capacitors are bad ones... Good Luck!
Posted on Nov 30, 2008
Liquidvideo desk top L17LCD2 turns on and off.
Yes! I think you would be further ahead getting a brand new monitor since they have come down in price.
Jun 24, 2012 | Liquid Video L17LCD2 17" Flat Panel LCD...
Black screen on L17lcd2
If you even manage to find some, I am almost completely sure it would be better to buy a new one when it comes to finances. Putting these parts together is a skilled technique. Also, if you have a guarantee with that monitor, why not return it.
Jan 15, 2009 | Liquid Video L17LCD2 17" Flat Panel LCD...
When i switch on my P.C. and my FP 5313 screen it flickers
This is a known problem with a series of components inside the monitor. There are about 11 capacitors that if replaced will allow the monitor to function properly.
The best place to go to read more is http://www.badcaps.net/forum/printthread.php?t=2658
The list of the capacitors that are bad are below with possible replacements.
C922, C925: Hermei LE 1000uF 16V, low impedance, general purpose, replacing with 1000uF 16V Samxon GF.
C201: Hermei LZ 150uF 25V, ultra low impedance, high ripple current, replacing with 1000uF 25V Samxon GF.
C924, C926, C929, C930, C932, C933: Hermei LT 470uF 16V, high ripple current, low impedance, replacing with 1000uF 16V Samxon GF.
C207: Unknown CD110 50uF 4.7uF (general purpose), replacing with a 35V 4.7uF tantalum unit (SCP/Short Circuit Protection pin on TL1451 won't get anywhere near 35V).
C907: WC (with stylized Westinghouse W) SM 22uF 50V (general purpose), replacing with 63V 100uF Samxon GF (used for SMPS controller Vcc filtering).
C905: Hermei HT 100uF 400V, standard, general purpose, leaving as is - generally no problem.
Dec 06, 2008 | HP Compaq FP5315 15" LCD Monitor
Hey listen i owned ur Liquid Video L17LCD2 (Silver) 17 in. Flat Panel LCD... and i had it for like 3 months and im haveing the same problemas everyone else it flickers on and off then i can see the screen...
There is no "instant" fix for this problem. A friend of mine gave me this same monitor 3 months ago & I just sat down to fix the unit. Here's what I did: http://www.wizardanswers.com/liquidvideorepair.html
I followed the exact steps & about $5 later I have a working monitor.
Nov 26, 2008 | Liquid Video L17LCD2 17" Flat Panel LCD...
Viewsonc VA720 Flickers On and Off Continuously
Take a look at the capacitors and see if you have any weak one. An obvious way to spot one would be one bubbled up on top. A bad cap won't always be bubbled up. The monitor probably can operate until the voltage drops under 8 volts. Also possible if power supply check out good would be a weak backlight inverter.
Apr 05, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Flickers on and off
are you sure its the only cap witch is faulty? maybe another one has broken down / about to.
Mar 29, 2008 | Liquid Video L17LCD2 17" Flat Panel LCD...
Comes on for about five seconds and then goes dark
MAKE SURE THE CONNECTION BETWEEN YOUR MONITOR AND YOUR COMPUTER IS PLUGGED IN TIGHTLY AND CORRECTLY, YOU MIGHT NEED A NEW POWER CABLE OR A NEW CABLE THAT CONNECTS FROM YOUR MONITOR TO YOUR COMPUTER, TRY CONNECTING YOUR MONITOR ON ITS OWN PLUG, OR IN ANOTHER SOCKET AROUND THE HOUSE IT MIGHT NOT BE GETTING ENOGH POWER, IF IT IS NOT LCD MONITOR (NOT FLAT) THEN YOUR COMPUTERS BULB MIGHT CIRCUT WRONG
Feb 20, 2008 | Liquid Video L17LCD2 17" Flat Panel LCD...
Blinking Blue Power Led on front, Monitor is non-responsive
Hallo.Sorry for me english first.I have question.You plugg in a monitor with a notebok,or dektop pc? If you conect monitor with a notebook, i thing, you must change a display settings.This is very easy.On the ntb keyboar press and hold Fn-key and at same time press f4 key,and you cann chage the output canal for video signal,Lcd in notebook,external LCd or Both. I hope, it will help for you. Bye Perdo
Jul 27, 2007 | Liquid Video L17LCD2 17" Flat Panel LCD...
The blue light of the monitor keep flash and no picture appears on the screen
I have exactly the same problem with my Medion 17" TFT monitor. It is not the video card (tried changing it) or the motherboard. Fitting a different monitor makes the problem go away. The monitor does not display the "No Signal" message when unplugged from the PC either. It must be a fault in the monitor, and as it seems to be a design fault. I suggest you contact Medion and nag for a replacement.
Dec 06, 2006 | Medion MD 7317 17" Flat Panel LCD Monitor
Liquid Video L17LCD2 17" Flat Panel LCD Monitor Logo
89 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
