Question about Water RHEEM 40 Gallon FVR PROP PWR Heater 42VP40FP
Is an oil burner efficient for a detached 2 car garage w 1 BR apt
I have a 2000 square foot 2 story garage with a 1 BR apartment in it. There is an oil burner for heat and hot water. There is no hot water heater. Is there a more efficient system? Should I replace it with a furnace and hot water heater? It seems to be inefficient and expensive. Thanks.
    Problem Solver:
  • 17 Answers
The best oil burner to use would be of the condensing combination type as this would be abt 96%efficient and only heat water as you needed it probably saving you abt 30% on your oil bill
Posted on Nov 27, 2008
The wire in my house for an elec. garage heater is 14 gauge wire with a 15 amp breaker. I assume i need at least 10 gauge wire with 20 amp .The heater is 20.9 amps and 3000-5000 watts, with 17500 BTUs
Curt, a 20 amp breaker will blow if you pull 10.9 amps from it. I suggest having a licensed electrician do your wiring. Likely, you need a permit anyway.
Oct 22, 2015 | Water Heaters
Can i convert a Rheem ECO 180DVP (LP gas unit) to a natural gas unit ?
Rheem water heaters should not be converted from propane to natural gas. The burners have been optimized for the rated gas and will not work as well after conversion. (Unlike ranges where the gas/air flow ratios can be adjusted when the burner orifices and regulator are swapped, the water heater doesn't have that option.)
I wish I had better news for you. I recommend you get a new water heater for the LNG service; it will be safer and more efficient.
Nov 10, 2014 | Rheem Tankless Hot Water Heater...
Central heating boiler (oil) will not start up - can you assist.
can you look inside combustion chamber and see if fuel is being coming out of nozzle and if you have a spark across the electrodes?. How long has it been since it has been taken apart and cleaned ? Has the oil filter been changed? You probably need to have it cleaned if this has not been done over a year.
Sep 22, 2014 | Water Heaters
Rennai hot water heater very slow to heat up!
I would check the gas pressure at the burner. It should be 3.5 inches water column on the manifold. Hope this helps.
Sep 09, 2014 | Water Heaters
Greenstar heatslave 9f 855 error code any body?
It is a burner lockout. Have you checked your oil level?
Jan 07, 2014 | Water Heaters
C2 11 code
Before calling service technician, open following link for Rheem error codes and troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code C2 11 is 'no ignition'
Ensure you have gas to the appliance.
Ensure gas type and pressure are correct.
Bleed all air from gas lines.
Ensure gas line, meter, and regulator are sized properly.
Ensure appliance is properly grounded.
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage.
There is no service bulletin covering how to perform these actions.
Rheem will ask that you call qualified service technician, who can give you tips and tricks for keeping the unit working, including opportunity for yearly service that will eliminate the expected $1-8 monthly savings from owning tankless.
Read manual for yearly maintenance needed to keep unit working at prime efficiency.
Apr 18, 2011 | Rheem Tankless Hot Water Heater...
Water heater runs for 40 seconds or so and stops, smell oil oder
Hello STOP!!!!! don't push the reset button any more.You have a ignition/spark problem.You will load the chamber with oil and will cause major problems when it lites off.Replace the ignition TRANSFORMER on the burner.Avalible for (beckett burner) at home depot/lowes.
Sep 20, 2010 | RTO Bock Water Heaters 51E 50 gal 152,000...
Our unit is housed outside of the house inside of a metal water heater housing that is sealed (vented to the roof ) Whenever we have a hard driving rain -the heater burners will not turn on. It seems that...
The flue should NEVER go straight up. Go up one foot, put a 90 then another 1-2 feet into a tee with condensate (rain) removal then go straight up. Make sure there is enough combustion air. Instructions are in the manual.
Feb 08, 2010 | Bosch 1600H-NG Natural Gas AquaStar...
Humming noise with my beckett burner
the beat i can do on this is an educated guess , it would be the pump or the pump motor bearings , but having said that i have also seen these make noise for years and not go out ,I have worked on oil burner about 35 years experience has taught me not to guess parts , so the advise i would give is to find the part and model numbers for the motor on the pump assembly and the pump try to find availability in your area , heating and cooling, hardware store ECT. and wait to see if becomes more defined or fails so you don't spend a fortune on parts you don't need ,**** make sure there are no oil ports on the pump motor bearings 9LITTLE OIL CAPS ECT OR PLASTIC PLUGS YOU CAN REMOVE TO OIL ) IF THERE IS PUT A COUPLE DROPS OF 3 IN 1 OIL AND SEE IF IT HELPS .
Feb 01, 2009 | Water Heaters
Water RHEEM 40 Gallon FVR PROP PWR  Heater 42VP40FP Logo
215 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
