Question about Eureka Vacuums
I have a Eureka 4870GZ. It turns on, but the brush roller doesn't move. The belt looks fine. I do have an extra belt and would try replacing the old belt, but I can't get the old one off the motor shaft or the new one on. I called Eureka customer service. The lady said there's supposed to be a small space between the motor shaft and the outside edge of the vacuum where I can slip the old belt off and the new one on. I don't see it. It looks like the motor shaft goes into a recessed place in the housing. Can you help me?
  • 1 more comment
  • Ina Fix Nov 12, 2008
    CoolGuy's URL did not help me. I can't remove the belt from the motor shaft. The end of the shaft is recessed into the casing.
    I followed the directions in the manual and took off the baseplate and the brush roller. The manual says to remove the belt but doesn't say how to get it off. There is no guard. There's just the housing. I don't know how to get it off, and I doubt that I should have to do that just to change a belt.
    Thanks for all of the ideas, but done worked. The last suggestion about removing the screws near the decorative holes did not allow me to remove the top cover. It allowed me to remove only the plate over the light bulb.I called the Eureka customer service again and spoke to a different representative. Apparently, Eureka has decided that my vacuum is defective. Since the nearest Eureka repair service is over 100 miles from my home, Eureka is going to send me a new vacuum.
    Sniper:
  • 69 Answers
Remove the top cover so that you can access to belt, You'll find 2 rows of 4 decorative holes on the top cover, In two of the holes you'll find the screws, Please use a flash light to see in that., Once the screws are removed, you'll be able to take out the top cover. Pull the belt so that it should rotate the shaft and look for small space in between from where you can take off the old belt and new belt on. remove the agitator from its drive shaft, put new belt in, put the agitator back into place.
Posted on Nov 12, 2008
    President:
  • 2,712 Answers
You will have to undo the top cover, from where you can access the area to change the belt. There are a lot of holes there once you open the cover, but you should be able to locate 2 or 3 (I'm not too sure), that hold the top in place. These may be a bit hard to find, but once done, you can remove the top cover and change the belt.
Hope that helps!
    President:
  • 1,952 Answers
It can only be activated in the upright/locked position (this is not specified in the directions, but appears to be true). , the negative reviewers point out quite correctly that
Moreover, the device comes with an extra belt-that the belt life is probably short and replacement in the short term is going to be inevitable.
  • mohammed marika thambi
    mohammed marika thambi Nov 12, 2008
    he handle release (pedal you step on) and brush roll on/off switch are
    a little stiff at first. In particular, the brush on/off switch may be
    difficult to operate for someone that has limited strength in their
    hands or a condition that makes it physicaly difficult to manipulate
    objects like this. [Dyson has a step-on latch that easily releases the
    vacuum from upright to vacuum position and a push-button to turn the
    brush on/off.]
    mohammed marika thambi Nov 14, 2008
    cool
    Sergeant:
    Champion:
  • 435 Answers
I found a solution in fixya. Lemme know if this works ...
I have an Eureka Whirlwind 5190.
Access to the belt is done by removing the top cover (not the bottom plate). On the top cover, there are two rows of decorative holes, 4 holes per row. Hidden in two of those holes are two screws, that once removed, will allow the top cover to come off.
The belt can then be replaced: remove the agitator from its drive shaft, put new belt in, put the agitator back into place.
- by AndyB
  • 734 Answers
The wheels rotating the shaft are damaged tooth (grip) that’s why your brush roller can’t able to moved.
Thank you for using FixYa.
  • futureloginn
    futureloginn Nov 12, 2008
    The wheels where you put the new belt are old (cause play between rubber and shaft) so, you need to replace the wheel where you put the new rubber)
    Sergeant:
    Champion:
  • 275 Answers
You may have to take part of the vacuume apart or therer is a removable guard
    Genius:
  • 3,422 Answers
Please click on the below link.You will see step by step explanation:
http://www.bobvila.com/HowTo_Library/Fixing_Vacuum_Cleaners-Central_Vacuum-F2190.html
Belt
Look underneath where the brush roller is located. The brush roller is removed to replace the belt. The new belt is installed on the motor shaft and the brush roller then the brush roller is reinstalled
Jul 27, 2013 | Eureka Whirlwind 4481 Upright Vacuum
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Trying to change the belt
things you will need Vacuum belt
  • Screwdriver
  1. Locate and purchase the correct belt for your Eureka vacuum cleaner from the local grocery or department store. Vacuum belts come in different sizes according to your model of vacuum. Check your owner's manual or the vacuum itself for your model number.
  2. Turn your vacuum cleaner over so that the bottom of the unit is facing you. Remove the cover plate from the bottom by undoing the screws that are holding it in place with a screwdriver.
  3. Locate the belt pulley rod near the back of the vacuum base coming out of the motor. With the vacuum cleaner base turned upside down and facing you, the motor and pulley rod should be up near the top of the base.
  4. Slide the vacuum brush roller out of the slots at the bottom of the vacuum base and remove the old belt from the brush roller and pulley rod. With the brush roller off of the unit, clean the brush by removing any strings or cords wrapped around the tube.
  5. Install the new belt by looping it over the belt pulley rod next to the motor and then looping around the end of the brush roller in the belt slot. Hold the brush roller and pull back on it to tighten the belt while you slide the roller back into the slots on the vacuum base.
  6. Replace the base cover plate by snapping it back into place and securing it with screws. Turn vacuum back upright and turn it on to test the belt and verify the unit is working
Feb 16, 2011 | Eureka Surfacemax 200 Bagless Upright...
Broken belt i need a replacement belt for eureka altima bagless vacuum
Eureka says size U BELT... NO!! I have tried this numerous times. I finally took off a belt from an old vac. and it works !!! dirt devil size 5 belt is the way to go!!
May 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
How to change belt on eureka whirlwind; what tool do I need
You will first need to remove the hood to gain access to the belt and brush roller. Turn the machine upside down, place the handle on the floor and the base on a counter. You will find several screws that hold on the hood, remove them. Turn the machine back to the upright position and remove the hood. On the right hand side,if your looking the front you will find where the belt goes. At the back you will find a silver shaft sticking out, put the new belt on there first. Then put the brush roller through the belt so it is in the carved out section of the brush roller. Then grab the brush roller by each end and stretch the belt till the brush roller fits back into the base. Turn the brush roller 3 compleat turns backwards and 3 forward to seat the belt in the proper position.
Then put back on the hood.
May 08, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Is the roller brush supposed to turn when the power is on?? the sucktion is on but the brush doesnt roll
That means that you need to replace the belt which turns the roller brush. Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Jan 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Jan 18, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
