The time on these watches has to be first properly referenced to UTC. I do not have the instruction book for your watch or even have a clue to the model number since you did not put any model number. There are several dozen Eco Drive models in each of the Citizen and Casio, and other type watches that are solar powered.
I have several types of Sky Hawk watches in the Citizen, and similar ones in the Casio. Check your instruction manual about how to set the UTC time, and how to set the offset time for your location. Once properly set up your watch should stay on time. If you have the radio receiver in your watch for the auto time setting, once the watch is set up properly it will maintain proper time all the time.
I need help in re-setting the proper BIOS setup for my HP Compaq d530 CMT (DC577AV) desktop computer. I used the Set Defaults option and need to set all settings back to where I was before the Set Defaults, but don't know the proper settings. Where can I get a detailed listing of the proper BIOS setup items?
Thanks..
Jerry
Have you ever been able to do this,...was it ever set-up properly to have this feature working.???
Check the installation instructions are set up properly and things like your e-mail address and POP accounts are set properly.
It is because the video resolution from your PC video card is too high for the monitor to display, you need to set it to native resolution of the monitor for best pictures but the game may not like it if itwats higher resolution. http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
two issues can affect.
1) you need to go into setting on your PS3 for your audio out settings and make sure they are set properly, then check for sound. That would be the best fix due to the PS3 HDMI settings are not set "on" by default. ( PCM AC3 settings must be correct).
If the PS3 is set properly... go into settings in the menu of the TV and make sure the input is set properly for the HDMI and make sure the speakers are actually turned on for that mode.
go the sound settings in advance option and see that u have done the settings properly. u have select the options properly u have the options called front sound enable and disable please do the needfull setting properly
Check settings for the hdd, check the jumper for proper setting, most of this computers come for cable select setting, set the jumper to proper position.
Yes, but make sure the settings have the Wireless headset aelected.
Normal
0
Also send this to your family
and friends so they have their computer setup properly. Web Camera’s have to be
setup on the program they are to be used with.Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
set it up as follows:
Go to Tools,
then Options, and click on Audio Settings and set the Microphone
and Speakers to the computer Audio Card.
Then
click on the Video Settings.
The
camera if Installed Properly will come up and show a video picture.
Then,
on the bottom of the page click on Save.
The camera and audio should function properly.Your friends and Family will now be able to
see and her to you. Hope this helps.Bud
