Question about EnGenius EOC-3220 (EOC3220)
Vista tuorial cannot set eoc-3220+ i on vista......disk tutorial works for XP but not vista. Where do I go from here?
  • 481 Answers
If you use the browser method documented in the accompanying manual, you should be able to configure this radio using any browser or operating system. It's much safer to learn how to configure without using "wizards" that only function on one OS or architecture.
Posted on Oct 28, 2009
My Seneo 3220 has changed its mac and gone to Realtek,can not log on to it any more,think its lost Engenius software. nigel 2205
I have no idea what it means for a Senao to "go to Realtek."
Here is the factory reset procedure for the Senao EOC-3220:
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Oct 25, 2010 | EnGenius EOC-3220 (EOC3220)
EOC-3220 connects but no internet access
What are you using for Internet connects? do you have the Access point connected to a Router. or is it connected to the Cable or DSL modem. I will need more information to complete this. If you have a router is is set to give an IP address or do you have a static IP? If it is set to give a Dynamic ip change the access point to recieve ip address from router and same with computer. If your connected directly to the Modem with the access point and you only have one IP address it will be used by the access point and not allow the computer to connect.
for more help please provide your internet (DSL, T1, CABLE) if you have router,  how it provides IP, and how access point is connected to it.
Oct 31, 2007 | EnGenius EOC-3220 (EOC3220)
Unable to connect to eoc3220 thru serial or network, any ideas
If you can connect to another, known-good EOC-3220 using the same serial cable and software setup, then your other EOC-3220 is probably just blown. It happens - I have several in a box in the workshop. :-(
Oct 11, 2010 | EnGenius EOC-3220 (EOC3220)
How do I get into my engenuis eco-3220? Someone messed with the ip address and I cant figure it out at all...or it will let me ping then not let me ping...going crazy
There is no reset button on this model. To forcibly regain control of the configuration, you need a USB to serial cable, possibly a null modem adapter (depending on the serial cable), and a serial communication program like HyperTerminal or ZTerm for the Mac.
The manufacturer has incomprehensibly removed the detailed reset instructions from their website, but they can be found here:
http://www.keenansystems.com/engenius__senao_wifi_faq.htm
Look for the section titled "How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? "
Aug 30, 2010 | EnGenius EOC-3220 (EOC3220)
I have EnGenius EOC-3220 (EOC3220) i can not reset with my null serial cable please help me
Depending on the serial cable you have, you may need a modem (crossover) adapter between the cable and the EOC-3220. A good diagnostic is the following: with the EOC-3220 unplugged from power, connect your serial cable and make all the proper baud rate etc. settings in your serial communications program. When it is running, plug the EOC-3220 into power. If you don't see any garbage characters appear on your screen when you plug the power in, your comm program is probably not set up properly. If you see garbage characters but they are not immediately followed by good information from the EOC-3220, then you either need a null modem adapter inline, or you have a dead EOC-3220. If you've never communicated successfully with an EOC-3220 before over the serial channel, the only way to know if you have a dead one is to try again with a known-good one.
Aug 12, 2010 | EnGenius EOC-3220 (EOC3220)
Username password
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Apr 18, 2009 | EnGenius EOC-3220 (EOC3220)
Stronger antenna
unscrew the antenna, and buy an rp-tnc connector and an n-male, then get an antenna with female n-type connector. LMR240 coax is better than RG58 for 2.4. which ever you use get the connectors to suit. Then crimp or solder them to your coax and away you go. no need for other settings ... just ssid of access point.
Oct 18, 2008 | EnGenius EOC-3220 (EOC3220)
EOC-3220ext Loosing its wired connection with lan
Try to Flush DNS Cache
ipconfig /flushDNS
Also
May 08, 2008 | EnGenius EOC-3220 (EOC3220)
Resetting the senao eoc-3220 long range wireless access point/bridge
Feb 21, 2008 | EnGenius EOC-3220 (EOC3220)
Config page
You will always use a straight through.moz-screenshot-1.jpg The default IP for this is  192.168.1.1 you also need to setup your PC with TCP\IP in order to log in. Go to network connections and double click on the  connection for the NIC. high light internet protocol TCP\IP and click properties.moz-screenshot-3.jpg then fill this in device IP 192.168.1.1 then  PC IP 192.168.1.10 then 255.255.255.0 then hit OK.  From there go to your browser and type http://192.168.1.1 there is no password or user name set the first time. moz-screenshot-2.jpgmoz-screenshot.jpg
Oct 27, 2007 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
76 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
