Question about Kodak Easyshare G600 (1633379) Dock / Cradle
Printer only prints half picture
The paper goes through printer but the left side does not print picture. right side is perfect. this printer has not been droped or abused
  • camilla75 Nov 14, 2008
    paper is in correctly and the carrier is clicked in properly.
  • Kodak Master
  • 1,879 Answers
Make sure that your Layout setting is on 1-up (full photo).
Posted on Nov 14, 2008
  • monk3ybidzness
    monk3ybidzness Nov 14, 2008
    2-up puts two photos in one sheet. Since you are trying to print 1, it'll be cropped and the other half is blank.
  • 6,487 Answers
If this was working fine before , it will be better if you can update the printer software to make sure this is not a software problem.........
  • Kodak Master
  • 13,433 Answers
Are you printing from the computer? if so it would be a good idea to check your settings and try reinstalling the printer and its drivers. To reinstall the printer, uninstall it, unplug it, remove all software ralated to it. Then reinstall the software from the cd or download from the makers website.
  • Kodak Master
  • 19,396 Answers
Check first that the print is not set to landscape, otherwise just change orientation.
If it is not that then it is a fuser not warming aenough the toner, a faulty toner, or a faulty drum.
  • 73 Answers
Check the printer properties--> paper and position settings
Canon digital 1xus75
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jan 13, 2014 | Canon Cameras
Windows vista wont allow Kodak G600 printer to print pictures using easyshare program
Hi lomls3,
Are you using Kodak Easyshare ver8? If not, you may need to update the software in order for Vista to send the print jobs to the Kodak G600 printer.
Update the software to ver 8 first. Reboot the computer and retry printing.
Ver 8 can be downloaded here: http://www.opendrivers.com/driver/293165/kodak-digital-camera-kodak-easyshare-software-update-8.0-windows-2000-xp-vista-win7-free-download.html
Hope this helps.
Andrew
Apr 04, 2010 | Kodak Easyshare G600 (1633379) Dock /...
I dont know what papaer to purchase for it i have bought some in the past but i forgot what it was i need abot 1000 pictures to print
1840339 Kodak Photo Paper Kit G100 ACTIVE 1DAI Accessories Sale inc VAT GBP 29.99
But this is only 100 pieces of paper. You might find it better to contact a KODAK distributor directly in order to get a better deal.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Kodak Printer Dock Series 3 won't print from computer
Run it using something other than the Easy share program. It tends to lock things up. If you have ANY other viewer, it will work.
Jul 30, 2009 | Kodak Cameras
How to add printing paper on kodak g600
Here's the manual for the G600.
http://www.kodak.com/global/en/service/publications/urg00536toc.jhtml
Loading paper is listed under "Getting Started". Remember to load the paper logo side down.
Hope this helps.
Mar 16, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Kodak easy share printer dock series 3 -printer wont work.
The thermal print head mechanism is probably jammed (It is the only large heavy metal piece inside the unit). To check, unplug all cords, remove two screws on back of unit, and then carefully lift top off unit. Unplug two ribbon cables that connect the top to the circuit board inside the unit (pull straight out on the circuit board end of the cables). You will see a metal shaft running across the width of the unit, approximately in the center front to back. This shaft drives the print head via a plastic lever on one end and a plastic sector gear on the other end. The sector gear is hidden under the circuit board. Depending on if the teeth of the sector gear are engaged, you should be able to rotate the shaft a fraction of a turn (1/8 to 1/4). If you need access to the sector gear, remove the circuit board by unplugging two more ribbon cables from the circuit board, and 3 screws holding the circuit board to the metal frame. Lift the circuit board and fan/fan-holder straight up as one piece, being careful not to stress the fan wires. Make sure the round metal bosses on the sides of the print head frame are under the plastic lever and sector gear. If this is O.K., check for freedom of gear movement by turning the large gear near the stepper motor in the rear corner of the unit. It should turn easily by pushing the teeth with a small screwdriver. The print head frame should move when the gear is turned.
Mar 15, 2009 | Kodak Cameras
Unit only prints on left half of paper?
Try reloading the drivers and also what model and make of printer are you having
Nov 13, 2008 | Cameras
Kodak Easyshare G600 (1633379) Dock / Cradle Logo
26 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
