Question about Epson Stylus Photo R300 InkJet Printer
Will not pull paper into printer...half the time
I have an Epson r300 I am having difficulties with pulling paper to the printer...it works then it does not work...I have used windex on a brush to clean the rollers...seems to work for awhile...then back the original problems...thanks for you help...
  • apmaj05 Nov 18, 2008
    I have been using good grade 20 lbs paper...it has had high volume use...
    If I hold a single sheet paper and push it down it catches...
    Thanks,
    andy J
  • Epson Master
  • 691 Answers
What sort of paper are you using? What sort of volume has the machine done? Have you ever had a jam and pulled the paper back out through the auto sheet feeder instead of feeding it through the exit rollers?
Posted on Nov 18, 2008
  • Inky Fingers
    Inky Fingers Nov 18, 2008
    You need to replace the feed tyre (feed roller) on the ASF. Once the rubber gets worn down, the machine looses the ability to apply enough pressure on the paper to feed is successfully.
Paper feed not working on Epson r300
If the paperfeed works when you "help" it a little, most likely the feed rollers simply need cleaning. We often suggest taking a little alcohol and spraying it onto some paper, and running it through several times, then running clean/dry paper through to finish. If the printer isn't even trying to load paper, possibly the paper sensor is blocked with dust, and blowing the insides of the printer may help.
Jan 14, 2015 | Epson Stylus Photo R300 InkJet Printer
Epson Photo Stylus R300 paper error
Please replace holder shaft & Roller ******
Sk. Abdus Sabur
Jan 01, 2010 | Epson Stylus Photo R300 InkJet Printer
How do you put the paper in the printer
usually there will be a paper tray that pulls out. you should read the manual that came with it. Usually they include pictures to help you.
Sep 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Mar 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson R300 Constant Paper Jam
Take it apart,as fas as you can.clean out all of the paper and chips. The print 5 pages only, twice as the Epson manual says to do , in order to clean itself out.
Dec 23, 2008 | Epson Stylus Photo R300 InkJet Printer
EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Nov 26, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R300 printer
ok " if you look in where the paper is loaded on top there is a small switch with a finger , may be bent. tells printer when paper is low
rubber wheels that pull paper threw may be glazed , take sand paper and go over wheels to ruff up
Jan 22, 2008 | Epson (C31C411016) Printer
Epson stylus photo R300
>disconnect printer from the computer
>powercycle the printer
>check for obstructions / torn papers inside unit
>if issue still persists - hardware issue
>warranty starts from the DATE OF PURCHASE better check
Dec 31, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson R300 printing only in top left corner of page
Change the paper settings in the driver when you go to print. If you have it set to 10x15 it will only print a 10x15 patch in the corner.
Go to START, PRINTERS AND FAXES then right click on R300 and select PROPERTIES. Click PRINTING PREFERENCES and set the correct paper properties. Click OK all the way to desk top and the settings will be saved.
On the printer panel press ADVANCED, scroll down 3 times to PAPER SIZE and press OK. Select A4 and press OK.
Dec 01, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus CX4600 pulling paper in crooked
Hi, please check if there is a paper jam or any obstruction inside that printer. Check also the platen lever or the left edge guide, make sure that paper is loaded correctly. Try printing again. If issue still present. Your printer needs to be send to service center.
--->>> Tirzo
Oct 12, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus Photo R300 InkJet Printer Logo
260 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
