Question about Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater...
PowerStar AE125 seems to have failed
This morning I received only a dark grey water discharge when turning on the hot water in the shower. The flow was greatly restricted. I checked the circuit breakers and one was tripped. When I reset it, the grey water continued, but was very hot and the flow still restricted. Any suggestions before I replace the unit?
The circuit board is gone bad, try this, with power off reset the overload on the heater.Turn power back on and turn on water to the unit. with no taps open hold the pipe near the left element for a few minutes. it will most likely getting verry hot and trip the overload.(this is done with no water running and power on to the unit).you may even hear the water in the left elemnet start to boil or sizle. the reason for this is the triacs on the cir board are bad.I have troubleshoot this troblem many times. the design is bad and their in now a new unit (redesign) out . bosch knows their junk and wont cover them beyond 1 yr. one way around it is call tech at bosch and tell them its leaking. the u will get one of the new designs. Also applies to the AE125, Rp27pt
Posted on Mar 07, 2012
  • 25 Answers
You have a blown element. If you purchased the heater, call Bosch for technical assistance, and the unit should be under warranty. The grey matter your getting is the magnesium that the elements have in them.
Posted on Jan 19, 2009
Powerstar ae125 runs hot then cold in shower
Increase your flow, sounds like you are right at your activation rate.
1 way is to turn down the temp on the machine, so you dont have to mix in so much cold at your shower. Check to see if your mixing valve is bad, or your showerhead has restriction/scale built up in it.The other way is to turn on your lavatory fixture full hot before showering(which will keep hot water flowing through the machine as you adjust your temp to be comfortable.
Nov 24, 2013 | Bosch PowerStar AE115 Tankless Water...
Power lite flickers onwater heater when drawing hot water
Light flashing while water is flowing means you have a bad control board. Needs to be replaced. They can be purchased online
Nov 10, 2013 | Bosch PowerStar AE125 AE125 Whole House...
What is the gray gravely discharge coming from my PowerStar AE125 when using the hot water? It plugs up the faucet and shower heads within minutes and almost completely blocks the water flow.
Heating water can peculate chemicals out of water, such as metals and organics.
Especially above 138 degrees.
Have well water tested.
Turn down thermostat temperature.
Or reasonably harmless well-water bacteria can react with anode rod, or other reaction in softener, to produce colored water, and smells.
Different water can produce different sludges, brown, red, gray, black, yellow.
The sludge can also combine with deteriorating pipe flakes to clog water flow.
Sludge can accumulate over years in low spots in pipes, or at elbows and constrictions.
Have plumber flush pipes.
Or run new pipes.
Also delime tankless yearly, and flush with white vinegar as shown in product manual, and treat bacteria with H2O2 hydrogen peroxide.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
Oct 29, 2012 | Bosch PowerStar AE125 AE125 Whole House...
The thermal cutout pops on tank two after it shuts off. It boils then shuts off. It also turns off when taking a shower, producing cold water. I checked the ohm readings on the thermal cutout and the...
Question posted under Bosch tankless.
Question says 'tank'
Brand, model, and type heater unknown.
Elements mean electric.
'Thermal cutout pops when taking shower produces cold water' indicates tankless, since tank-type would maintain some hot water.
No error code might indicate tank-type.
Add a comment with type, brand and model number of heater for possible assistance.
Sep 24, 2012 | Bosch PowerStar AE125 AE125 Whole House...
My Powerstar tankless water heater was installed last April and we have a problem that has become a real issue. We can set the temperature where we want it and get in the shower and the water will go from...
Ok, sounds like a flow sensor issue, is your house water pressure steady or does it fluctuate? The sensors on these seem to be a common issue and this model has many issues with heating. take care
Jan 17, 2011 | Bosch PowerStar AE125 AE125 Whole House...
Heater is ae125 is about 2.5 years old no problem until now turned on water and but no hot water light or anything checked breakers,checked cutouts,plenty of flow,still no hot water
Hey did you ever get this fixed mine is almost the exact same thing we've been using ours for about 3 years and today nothing. Thanks for your help.
Dec 07, 2010 | Bosch PowerStar AE125 AE125 Whole House...
Easiboost power shower - problem
it comes on when the pressure changes so when you open another faucet it changes the pressure and makes it come on,, check your pressure regulator valve on the main line comming into the house it has a screw in the center, if you have a pressue gage put it on either the water heater drain or out side hose bib , check the pressure when turning water on and off if it changes more then 5 lbs you need to change your prv valve. pressure regulator valve,
Feb 17, 2009 | Bosch PowerStar AE125 AE125 Whole House...
Only goes on when I put hot water on full blast
hi, i expect the problem to be because the flow switch which activates the heater wont switch the heater on as it requires a certain amount of water to activate the flow switch & then bring it on.
It may also be thatthe sensor on the flow switch is scaled up so it needs a greater flow to keep the heater running?
Sensor or flow switch may need replacing.
kindly
Richie
Dec 12, 2008 | Bosch PowerStar AE125 AE125 Whole House...
Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater... Logo
419 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
