Question about Home
How to best use Stanley Mirror Mastic?
I am installing a 4ft X 6ft bathroom mirror on a 1/4 inch thick equally sized sheet of plywood already installed on the bathroom wall. I'm using a L bracket bracket on the bottom for support and planning to use Stanly Mirror Mastic on the back of the mirror. After the mirror is installed, a ''picture'' frame will be installed on top of the mirror/plywood backer board. I am uncertain about how to use the Mastic as I have never used it before.
What is the best way to use the Mastic? Do I have to use clips at the top of the mirror or will the mastic hold it to the wall?
Jerry
    Genius:
  • 1,605 Answers
Make sure the wall where the mirror is going to be, is perfectly flat.
if you are going to install the 4x6 ft mirror. you need minimum of 3/8" board, if not 1/2".
yu use mastic the same way you use caulking. on the safety side, I recommend you install upper and lower railing.
the mastic will hold the mirror, three glop on each side and enough in the body of the mirror. press on hard, but too hard you will break the mirror
the mastic will take about a week to cure completely.
Posted on Nov 18, 2008
Slate bathroom tile
First clean floor down to plywood. Then buy mastic, notched trowel and tile spacers from hardware store. Lay out tile in the pattern you want by cutting them with a tile saw you rented. take out dry laid tile and mastic a small area and install til making sure you press the tile into mastic. Insert spacer and install next tile.
May 16, 2013 | Home
What kind of mirror should I use in my bathroom?
All bathrooms need a mirror - it's the place you are most likely to shave, do your facial care routine and dry your hair.
When choosing a mirror for the bathroom, pick one that is the same width as your vanity/ sink unit otherwise it won't blend with the design of the room.
Feb 18, 2013 | Home
4ft.X 6ft X 18in What is the volume of water by gallons
1 US Gallon = 231 Cubic Inches
You have 4 X12X6X12X18=62,208 cubic inches so
62,208 divided by 231 = 269.3 gallons.
Hope that helps..................Pete
Jul 17, 2011 | Garden
Drywall hole
cut the drywall, square,from the center of one stud to the center of the next stud and remove. Now cut a new piece to fit and nail or screw in place. Tape the joints with mesh tape and coat with drywall mud. Use a ten inch broad knife for this. One coat of mud and let dry. Next day another coat of mud pull it tight this time and let dry Sand and apply desired texture
Jun 18, 2010 | Saws
Mirror glued to wall
That's actually a pretty common method for professionally installing bathroom mirrors. As you mentioned, tape a star pattern on the mirror and then use a thin piece of piano type wire to slice through the adhesive. Keep the ends of the wire as close to the wall as possible while cutting so that you don't break the mirror. A local glass company can provide the best type of wire for the job as well as tips on the best way to get the job done - particularly if you imply that you'llbe buying your new miror from them. Be sure to wear leather palmed gloves and eye protection when doing this job!
May 31, 2010 | Home
Cost of a portion of a sheet of plywood.
since 12*8=96 this implies that 96' costs 30$ .and 96" will cost 30/12=2.5$ since i feet equals 12 inches
Mar 05, 2010 | Vivendi Excel@ Mathematics Study Skills...
The staples are not going deep enough into our hardwood. We tried a different nailer as well, and the cleats wouldn't work either. Tried both 1 1/2" and 2" staples and cleats. We're installing 3/4 inch oak...
The working pressure of this tool is 85 - 90 PSI max. Do not over power it or you risk O-ring breakage. These guns are adjustable for floor thickness. The adjustment is simply by adding and removing shims on the floor contact part of the tool. For 3/4" the pad should be 5/16" thick without shims
Jan 03, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
Cut off question
Here a few examples: * 5 inch trim saws, usually with a fine-toothed blade and often with the blade located on the left side of the motor, for easy viewing of the blade path. These are available in 120V, AC models, and rechargeable battery models in various DC voltages. * 6 1/2 inch saws, as shown in the illustration above, used for cutting to length nominal lumber for construction, as well as ripping lumber, and cutting plywood or composite material. * 7 1/4 inch saws, often call skillsaws, from the name of a major circular saw manufacturer, Skill. These are the backbone of the construction industry, used for cutting lumber up to 2 1/4 inch thick. They are used for cutting framing lumber to length, and ripping lumber. They also have a number of optional blades which can be used for cutting composite materials, concrete, ferrous and nonferrous metal sheeting, pipe, tubing, and even cold-rolled steel bar stock. * 8 and 10 inch saws, used for cutting to length larger lumber or timbers, up to 4 inches thick. These are heavier, more cumbersome tools used mostly in industrial work. * Worm-drive saws have a gearbox with a worm-geardrive, and are found in 7 1/4 inch models which are most commonly used for ripping lumber or cutting plywood decking or sheathing. They typically have the blade on the left side of the machine, to make watching the blade path easier when cutting parallel to the edge of a wide sheet of plywood.
Aug 27, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Home Logo
1,104 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
