Question about Microsoft Windows XP Professional
When installing a used hd...PC says no hard drive found
  • 50 Answers
Do you have another harddisk installed already if so, you need to change the jumper settings maybe both the hardisks are having the jumper positioned as master device. which u need to set ur OS or Operating software HDD to master and the second one as a slave.
Posted on Nov 13, 2008
My old hard drive on my COMPAQ PRESARIO C306US died, after I replaced the drive I tried reloading windows XP and I get an error that the hard drive could not be found. I loaded Ubuntu and it recognized the...
check the HD if its properly inserted,if the old one is working before then the new one you bought my be a damage one. try to replace another HD to see if which HD is working or not.
Jun 06, 2011 | HP Compaq Presario C306US Notebook
Hi, I have a Seagate ST38421A HDD in an EMachines EOne PC, very old, Win98. When I turn on the PC it says there is no HD found in the system, and when I try to install Windows XP, it says it has no...
Sorry to say it it but your hard drive in your computer has stopes working. Best way to fix it is to buy a new hard drive for your computer or just buy a brand new computers.
Mar 04, 2011 | Seagate U4 8421 (ST38421A) Hard Drive
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
May 19, 2010 | HP Compaq Presario SR1010V (568656) PC...
I am installing a new WD3200AAJB HD in a Dell Dimension 4550. This is the only HD in the system. There are also 2 CD drives and a floppy drive. I used the jumper settings the drive came with which pins...
Reinstall your old hard drive as master and install the new hard drive as slave.
Here is the link to jumper settings from Westrn Digital;
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1540&p_created=#jumper
If you've got your jumper settings wrong and installed your os on the 127 GB section of the 320 GB Hard drive and you change jumper settings and then you have problems you may need to reinstall the old hard drive as master and the new hard drive as slave. Reformat the new hard drive as 320 GB, and as a bootable drive. You can either do a disk copy from old to new or reinstall your os on the 320 GB drive. Please let me know how this goes. You can get to me @ johnkariotisjr91741@yahoo.com
Oct 25, 2009 | Dell Dimension 4550 PC Desktop
Hard Drive not found
try checking this issue using some other HD if the other one works fine then get this one replaced..
May 30, 2009 | Dell Latitude CPI-D Notebook
Hard drive died & replaced with a new hd
Make sure your pc is recognizing the drive before installing any program. If the drive is recognized but is still not booting, then reset your pc as soon as the pops up press f12 which will show a list of the booting order you of course will want to select cd drive or you can enter f2 and make the booting configuation changes thru your BIOS in the Booting Sequence. change the order or replace the drive or drivers and Voila Your good to go, Hope this helps
Good Luck =)
May 29, 2009 | Dell Latitude D505 Notebook
I installed a new hard drive in a Gateway 4XL.
See your hard disk Jumper setting it could be wrong change jumper of your hard disk then install the windows.
Mar 07, 2009 | Gateway Profile 4 XLb PC Desktop
Hard drive not found
Wayneard is correct. When you install a brand new hard drive as the ONLY hard drive in the computer, there is no operating system loaded. The computer will try to boot from the hard drive and stop. Switch your boot order to have the CD boot first, and be sure you have the operating system installation CD in your CD drive.
Also, double check your hard drive connections. Be sure it is in the "master" position on the hard drive cable. If there is a connection problem, the system will complain after CD start that there is no hard drive available to install the operating system on!
Good luck.
Dec 30, 2008 | IBM NetVista PC Desktop
Intel Pentium IV Trouble (40gig)
os not found usually means that your hd is faulty.
try remove hd and reseat it.
if no joy have os disk(windows) in cd drive start pc and boot from disk.
select install windows...system checks drive and informs of existing os..want to continue...install windows...next screen shows partitions.choose to delete partition then create new then format and install.
if when u try to boot from disk system say no hd found then hd is damaged.
Mar 14, 2008 | Computers & Internet
Boot up problem
youre hd needs an os installing on it.first partition,then format ,then install os(windows)
the system is looking for a os not a hd ;the beeps indicate no os found(no drive by default)
if there is no hd,memory,or video card or stuck key the pc will beep.also with video card not connected the screen will be blank also with many models no memory will result blank screen.In ur case its only the hd.make sure all items are fitted insert os disk in cd drive start pc and boot from cd,to create partition,format and install
Mar 04, 2008 | HP Pavilion dv6000z Notebook
Microsoft Windows XP Professional Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
