Question about Hitachi 53UWX10B 53" Rear Projection Television
Possible convergance issue
This TV has worked great for 5 years. Today the picture is not lined up and red, green, blue lines appear around everything. Picture is out of focus. The Magic Focus button goes thru its process, but then puts up a number "4" at the end... and the problem still exists. My biggest problem is that I am now living outside the US and will probably have problems finding anyone who can fix it. I read another email from someone who seemed to have almost the same problem and was wondering if the convergence amp was the problem. Is it something that snaps in an out.... or am I out of luck?
Use hitachi convergence kit STK392-150, I just had the same exact issue, u can buy this kit on the internet or a local TV shop, kit costs from $25.00 to $35.00. The convergence board is located (loking from the back of the TV) on the lower right side, its a long board, u'll have to remove it (all plugs should be labeled) and remove the old componets, and replace with this kit. After I installed it, did 1 magic focus, and it was perfect again
Posted on Jun 18, 2007
I had the same problem and they replaced the red converter IC.
Posted on Jun 08, 2007
The screen is distorted ... double words and double picture
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synchronous.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
Good luck in solving the problem....
May 27, 2011 | LG 50PG20 50 in. Plasma HDTV
I have a green and red shadow on the words. It appears towards the top and bottom of the screen.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Since it is 4-5 years old it's a 50-50 chance that the TV has the auto feature. Good luck and if you still have the owners manual, I would read up on the convergence section in the manual.
Take in solving the problem.....
Jan 12, 2011 | Philips Magnavox 51MP392H Rear Projection...
The left side of the picture is distorted with a double image. The right side is fine. As things such as the stock symbols on CNBC scroll across from right to left on the screen, they start out looking...
Hope this will help in solving the problem....
Jan 12, 2011 | Hitachi 51GWX20B 51" Rear Projection...
Poor Picture
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the curser (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
Hope this help....
Jun 26, 2010 | Sony Bravia KDL-32V4000 32 in. LCD TV
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Cant get the Multipoint red/blue set right
Most likely your convergence circuit needs repair, there are 2 large IC chips with heat sinks (labeled STKxxx -XXX) and possibly depending on model a resistor or fuse may have went with it. 95% of the time this is all it is. It could cost $300-400 to have someone repair it.
Rustym62
http://the-tv-dude.blogspot.com
May 04, 2009 | Televison & Video
Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Red and blue
convergence amp ic going bad.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Out of Focus
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Nov 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Out of Focus
if you have no experience repairing TV sets your going to have to have a tech replace the convergence ICs they are soldered into place and will probably need to be readjusted when this is done. if you know how to work on tvs then replacing the STK type ics in a pair is whats needed Good Luck
Aug 16, 2006 | Samsung HCN653W 65" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
