SAMSUNG LNT3232H LCD TV FLICKERING BACKLIGHT
I have had this TV for little over a year and what seems like the day the warranty expired I began having problems with the backlight. What happens is the screen starts to flicker slightly and eventually goes to black
(no backlight, but still audio), the the set then shuts down and powers up by itself and works with no problems until the next occurrence. It is intermittent, but happens sometimes as often as every 15 minutes.
I have be told it could be the backlight, inverter, or SMPS ; any ideas and if parts are available?
  • Anonymous Mar 02, 2009
    I have a 46" SAMSUNG 650 LCD TV. After about three months the backlight flickers for a few seconds and then goes out completely. Luckily, I'm still under warranty. You should still contact Samsung customer service. I'm sure something has to be replaced/fixed.
I have a ln-s4092d that had the same problem after a little more than a year of service. Replacing the main board seemed to fix the problem. But about a year later, the same problem has reappeared. I'm getting ready to replace the main board once again, but I don't really want to do this on an annual basis/
Posted on Aug 14, 2009
Samsung LED tv horizontal lines
Your lcd screen itself or the led-backlight matrix of your lcd screen have this problem ( if there was not worked insite the house or room with wallpaper chipping or new wallpaper?), the answer is to get warranty if it is within the warranty-time in most cases its happens by over 4 a 5 years old SAMSUNG (led backlight matrix) lcd tv's ?? or younger have no heard of this problems by the older lcd ccfl lamp backlight devices.
There is usually no thorough repair option for known as it seems in practice
A great hobby capacitor-rolling option to do ?who should know ? if they look bulged or have leaked on some places, but if there where leaking capacitors there can be damaged print circuit lines on some places on the circuit boards to find if it is find by little brown spots under capacitors.
Beware of people watch out for those who want to empty the rack.
Its maybe a new worldwide problem in much cases and the service oft too. turns out.
To read use a add-on translator and read that its one of an little epidemic question.
Radar Toon onderwerp archief Samsung LCD LE 46M87BD
May 05, 2016 | Samsung Televison & Video
I've owned a Vizio VT420M for just over 13 months. About a week ago the tv started flickering when I turn it on. The picture is visable, but the area around the actors is flickering. After about 7 to 10...
The flickering is most likely due to a faulty fluorescent backlight. Once the bulb heats up the flickering usually goes away. Some bulbs are easier to replace than others so I would contact your local TV repair shop.
Mar 01, 2011 | Vizio VT420M LCD TV
Screen has started to flicker constantly. tv is 9 months old. When switched off flickering stops for about 5-10 minutes and then starts again
I had the same issue occur on my ln55c650 and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Feb 23, 2011 | Samsung LN55C650 TV
Samsung LCD TV doesn't power on, just blinks 5 times
After about 5 years the Samsung LCD televisions backlight fails which prevents the TV from coming on and the powerlight just flickers the backlight can be changed but it is often alot easier and cheaper to buy a new Television
Sep 14, 2009 | Samsung LNT2642H 26 in. LCD Television
HP Pavilion Entertainment Laptop Monitor flickers black
If the laptop is under a year old it could still be under warranty and if so I would get it repaired under warranty.
OTHERWISE
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 02, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Emerson LC320EM82 S LCD TV I purchased this TV a year and 3 weeks ago. It suddenly stopped powering on. When I turn it on the screen comes on for half a second with 3-4 inch white lines across middle of...
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Jun 18, 2009 | Emerson LC320EM8 32 in. LCD TV
SAMSUNG PROBLEMS - Red and Green Shading All Over Screen
adjust vscan  vs & va voltages on power supply, if not that drive pcb's are bad
Jun 05, 2009 | Samsung LN-S4051D 40 in. LCD Television
Soyo 32" LCD flat panel
Better to send it back before the warranty expires, the set has issues
Oct 21, 2006 | Soyo DYLT032D 32 in. LCD Television
Televison & Video Logo
3,499 people viewed this question
Top Televison & Video Experts
