Question about NEC Electra Elite DTU 16D-2 Corded Phone
Can't answer direct line calls
We have one phone in the office that will not answer a direct line call. It flashes and rings, but picking up the handset; pressing answer; or using the 67 pickup feature do not work. Other users can pick the call up with 67+line, but not that handset. The user can access voicemail on the handset, and it is not set to forward or DND. All other users are able to answer their phones by simply picking up the handset on a direct line incoming call. Any help???
  • Anonymous Mar 26, 2014
    phone not answering on pick up
    Problem Solver:
  • 13 Answers
This sounds like a programming issue on this telephone. There are 2 areas in programming that would cause this. If you have recently had a technician out to do some programming then it is possible that he made a mistake and needs to be called back to correct his mistake.
Posted on Dec 08, 2008
Old Norstar phone-one line seemingly tied to one extension
You most likely need to call in your tech who looks after the programming there.
Needle in haystack, sticky button, bad programming, glitch in system, answer dn etc.
Dec 10, 2012 | NorStar M7310 Corded Phone
I hooked up a phone in the office on an extended line from another area and all of the memory buttons automatically worked, but the phone doesn't ring even after using feature *6 selecting a ring, and...
The easiest thing to do is use Direct Pickup Feature.
When the phone is ringing dial Feature 76
Dial internal number of a phone that is ringing (also refered as extension number)
You just answered a ringing phone at your desk.
If you have login information for Feature **config, I can help you set up your phone to be ringing as well.
Cheers
Jun 24, 2009 | NorStar M7310 Corded Phone
Norstar M7310 phone doesn't ring and doesn't pick up calls
You can look at the manual here:
http://www.fixya.com/support/p98000-norstar_m7310_corded_phone_nt8b21ac03/manual-34096/page-3
Trouble with call forwarding to our multiple lines & voicemail
It's not and they're idiots. The hunt sequence you describe CF-No answer is part of their arrangement, probably Centrex/Centranet.
This is one of the sloppiest setups they can possibly give you, but it relates to destinations for CF busy and CF no answer. Get someone who has a clue and tell them to adjust the time on the No Answer part, or, better yet, give you something that really works.
Carl
Jun 01, 2009 | Vodavi 30-BUTTONVODAV XTS Telephone
How do you forward a phone call from this phone to a cell phone?
to forward calls...go to your phone service providers website and help section for complete instructions...
with most companies simply pick up the phone... wait for dial tone... press *72 wait for 2 beeps and enter the number (area code first) that you would like it to forward to...once you enter the number wait for the line to ring... once it rings and is answered you are all set!
if it doesnt ring or is in use.. try again within two minutes...you should hear two short rings if it is activated...
to deactivate call forwarding...
pick up the phone (in the office)
wait for dial tone and dial *73 or #73
you will hear two short beeps... it is then off..
Apr 10, 2009 | Panasonic KX-TS3282B Corded Phone
DO not disturb feature will not turn off
do not pick up the headset
push feature 69 feature
Jan 20, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Pick up handset to answer a call and NOT have to press a line
if your phone had set for ringging assignment, u no need to press any key to answer the call.
check the indicator light,
if green light turn on, u can direct answer the call
if red light turn on, u ned to press the line to answer the call
kindly ask the phone provider the set yr extention for incoming ring assignment
Nov 12, 2008 | Toshiba DKT-2020 Corded Phone
Receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
How do you answer another phone in the office by using your own phone
Ascertain from your system administrator the directed call pickup feature access code, this will allow you to pickup any ringing call as long as you know what ext number is ringing.
Jul 11, 2008 | Mitel 5220 IP Phone
Mitel 5220 IP phone won't ring when the main line is ringing
WOW
Ok this post is OLD, but for anyone else having this issue, this is the solution...
There is a programming feature that states: DELAYED RING on certain lines, meaning you can physically see a call coming in to the system (via line flashing), but it will not ring at your desk till something like the 4th ring(hence the name DELAYED ring).
If your set does not ring, and you pick up the heandset, the phone system doesn't know if you want to answer the call -or- you just want to make an outgoing call...
Therefore the Mitel system picks up internal dialtone and waits for you to make the initial reaction (hit 9 for a line out or hit a line that is flashing on the set).
Too change this option, a Mitel Tech is required...
Jan 23, 2007 | Mitel 5220 IP Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
305 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
