Plasma - screen is black even with power on.
The proposed sulution to my problem was - replace the lamp.
Plasma TV's don't have lamps. So what now.
  • 734 Answers
If you are not a tv mechanic then you might not be able to solve this problem, so you will have to get it repaired at a service center.
Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 12, 2008
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
I got the 'lamp needs replacing' message. Ignored it. Now my tv screen is black when you try to turn it on and the blue button on the power button flashes?
You haven't replaced the lamp at time. Replace a new lamp along with its ballast and make a lamp time reset. If you wish to get more details about the lamp replacing procedure to Panasonic PTVs, check this link.
Feb 05, 2013 | Panasonic PT-44LCX65 Television
Its a fujitsu siemens I think its 56 inch (its 1 meter 27 centimeter). The tv has a black stripe in the middle,horizontal all over the screen.Its getting bigger.At first it flickered now its egally...
Hello
The backlight bulb at its center has damaged. There will be more than 12 CCFL lamps which comes about the entire length of the screen at the backside of LCD screen to illumiate the screen, ahich in turn adjust its brighness according to the brighness we controls with remote. The center one of your TV is now bad. It can be replaced. You have to open your TV and disassemble the lcd unit to see and replace this lamp. If you are not familier with this work, get it repaired by some experienced service technician. It can be repaired at home. The lamp will have its ratings marked on it. Choose the same rated lamp. OK.
Jul 09, 2011 | Fujitsu Siemens Plasmavision P55XHA30 55...
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
TV turned on, heard loud pop. Now screen is very dark.
It sounds like the actual tube / lamp inside the unit has exploded. You will need to either get it repaired at a local TV repair shop or replace the TV. Unfortunately with that unit it is probably cheaper to just replace it.
Jul 27, 2010 | Akai PDP4225M 42 in. Plasma Television
My phillips 42 inch plasma tv just clicks when I
There is no lamp in a Plasma TV screen and no ballast.
Check the power supply capacitors.
Aug 19, 2017 | Philips 42PFP5332D 42 in. Plasma...
Blank screen
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Mar 11, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Lights flashing and no piture or sound
I had the same problem a little over a year ago. It was the lamp. It needed to be replaced. I hope you have the extended warranty.
Jan 08, 2008 | Hitachi 50V720 Television
Black Screen
It sounds as if the lamp has failed possibly due to a failed cooling fan (the fan should be the first thing to come on). here are the links to the user manual if you need it; http://merchant.satisfusion.com/sf/library/manuals/owners/50_55_60VG825.pdf and http://merchant.satisfusion.com/sf/library/manuals/owners/50_55_60VG825_Part2.pdf It may be worth trying to uninstall and reinstall the lamp, but usually these fail internally rather than having bad connections etc. It is often obvious when the lamp has gone from a visual inspection. If the lamp has failed, when you replace it, make sure the fan comes on - if not then turn off instantly and investigate further. One other possibility before buying a new lamp, is that the lamp compartment cover may not be properly fitted. This will interrupt the power, so I am assuming there is a microswitch or similar that the cover or the screws that hold it should contact. Possibility is that the cover is badly fitted, or a small piece of the cover has broken, which would normally contact the switch, or the switch is faulty - if you can see the switch then a continuity meter will easily test the switch. Also check that the lamp unit securing screws are properly tightened, they also may stop the TV powering on. Please ask again if you need more help with this, if you are unsure then a photo of the inside of the lamp compartment and the lamp itself may help :)
Jun 26, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Monitor goes black and both blue lamp blinks
have a tech check your tv there is a fault in tv horizontal circuit.good luck my friend.
Jun 15, 2007 | JVC PD-42V475 42 in. HD-Ready Plasma...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
