Question about Philips Magnavox DVD/VCR Dual Player
Clock time always goes back one hour after setting it.
After setting the clock, within a few hours it will change and show one hour earlier. This all began after daylight savings time started. I've turned off the automatic time setting and set it manually, but no help
  • Anonymous Nov 27, 2008
    I have been trying every possible setting. The clock always re-adjusts to one hour off. Even if you try to trick it, it resets to one hour off. I spoke to Phillips. They are aware of the problem and told me "if it is under warrantee, send it back and they would replace the unit." I have also seen this same problem with other manufactures.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
Check on the general set up/ clock, what zone is set and put east, mis or west deppending where are you located, turn on the automatic clock or select a news channel where the decices will check the update time.
Posted on Nov 19, 2008
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
Want to change time on clock of Goodmans TCB20SG microwave
1. Hold the Timer/Clock button down for a few seconds till it beeps and shows 12/24 hours.2. Type the time into the display. Use the minute buttons to set the hour, and the second buttons to set the minutes. 3. Press the clock button again.
Apr 03, 2013 | Microwave Ovens
Set tme 4837 clock radio
I have the same clock radio and I found out that you have to hold down the button and run through the times. The hour will change with the minutes. It goes pretty fast once you hold down the button, so I stop when I get close (like within 20 minutes of where I need it to be) and then click it one minute at a time until it's at the right time.
Jun 09, 2012 | GE 7-4837 Clock Radio
Need to change the clock in my jimmy and dont know how,,theres no manuel
I found this solution already was answered by: chavezemail
Rank: Wiz gmc.gif Expert
Rating: 87%, 24 votes
Owners manual: 3-10:
Setting the Clock for Systems with HR and
MN Buttons
Press and hold HR until the correct hour appears on the
display. Press and hold MN until the correct minute
appears on the display. To display the clock with the
ignition off, press RECALL or HR/MN and the time
will be displayed for a few seconds. There is an initial
two-second delay before the clock goes into the
time-set mode.
SET Button
Press SET. Within five seconds, press and hold the
SEEK right arrow until the correct minute appears on
the display. Press and hold the SEEK left arrow until the
correct hour appears on the display.
Jul 12, 2010 | 2000 GMC Jimmy
How do I set the clock on a room tech beingz
There is a switch on the back to set time, alarm, or display time. Select the switch to time set first. Tap top of unit to toggle between settings blinking display is the one to be set. Change it bi tapping on the sides ( ) or(-) don't forget the 12 hour display or military 24hour. Switch back to clock display when hour and minute display are both blinking or the setting will not take effect
Jan 26, 2010 | Hasbro Room Tech Beingz Alarm Clock Radio...
How to set clock in 2000 GMC JIMMY
MN Buttons
time-set mode.
SET Button
Nov 13, 2009 | Car Audio & Video
I can't set the time on my car stereo ,How do you set the time on a jensen mp 5720
7. Clock
CLOCK DISPLAY
Press the DISP (16) button to show the clock in the display. The clock will display for a few
seconds and then return to the previous display.
CLOCK ADJUSTMENT (TIME)
Press the DISP (16) button to show the clock, and then press the DISP button again and hold for
> 3 seconds until the clock flashes. Press the DOWN TUNING (<<-) button (18) to change the
minutes and UP TUNING (+>>) button (17) to change the hour. Continue changing the hour to
move between AM and PM.
Here is a link to the manual where this text cam from:
http://www.audiovox.com/manuals/owners/MP5720_123103_FINAL.pdf
Jun 01, 2009 | Jensen MP5720 CD Player
After a power outage, my clock no longer has right time
You need to reset the microprocessor in the Clock/Radio. to do this you must unplug the Clock/ Radio and remove the battery. Let the Clock/Radio set for at least 1 hour to discharge the microprocessor. You can then reinsert the battery and plug in the Clock/Radio. The functions should return to normal. If you are still having a problem, try changing the battery (CR2430) and letting the Clock/Radio set unplugged for a longer period of time. If all this fails, you can call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT and ask them for assistance. I hope this information help you with your problem.
Apr 01, 2009 | Emerson Smartset Clock Radio
Setting the clock
Setting the Clock for Systems with the
Set Button
Press SET. Within five seconds, press and hold the right
SEEK arrow until the correct minute appears on the
display. Press and hold the left SEEK arrow until the
and MN Buttons
time-set mode
Nov 13, 2008 | 2002 Chevrolet Silverado 2500HD
Philips Magnavox DVD/VCR Dual Player Logo
138 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
