It is very blurry and it cant auto focus. I reset the device and nothing worked. help?!
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
SOURCE: I have the Kodak M530 Easyshare camera and
Press MENU, then use left/right to select the Setup tab. Language should be the ninth item on this menu. Select it, and you should see "English" as one of the choices.
Checkout this tip about digital camera error
messages
Lens
Error fix for Digital Camera
heatman101
and when I turn it on, it will make noise like it was something stuck
