Question about Radio Shack Pro-2096 Base Scanner
Picks up motor sounds when transmitting
Is there a device to control this
  • bmitchem Nov 12, 2008
    Base/Mobile radio scanner PRO 2054 picks up motor noise.Can you suggest a way to fix the problem
    Problem Solver:
  • 14 Answers
The same thing happens to me with my pro-82 from radio shack. they say the sun flares explode and interfere with radio communications. is this the only thing that it picks up? get back to me on that.
Posted on Nov 15, 2008
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
I have a nokia lumia 625 and it does not pick up 5ghz wifi, any clues. It picks up 2.4ghz ok.
You can only get higher than 2.4ghz from your router if you are using a ''wireless N'' router and your phone must be wireless N capable. The fact that you are asking this question, probably means your phone is capable of ''N'' reception, but your router is not ''N'' compliant. You are probably using a ''B'' and/or ''G'' type router, which would definitely only transmit at 2.4ghz. // By the way, even ''N'' can be transmitted at 2.4ghz. The ''ghz'' isn't as important as whether or not the router can transmit ''N'' wifi frequency. You can tell by the download speed. ''B'' & ''G'' won't transmit faster than 54gb per second. The ''N'' speed is upwards of 100gb per second. All three (''A'', ''B'' & ''N'') can be transmitted at 2.4ghz if that is the router's rating. The ghz is not really about ''speed''. It is about the fact that many wireless devices (such as landline telephones) transmit at 2.4ghz, which can interfere with the router's 2.4ghz signal. So, using a router that transmits at 5ghz won't have interference issues with other 2.4ghz wireless equipment. // In short, what matters is that your wireless ROUTER transmits with the ''N'' version of wifi.
Jan 01, 2015 | Nokia Cell Phones
WiFi
try getting closer to the router, not all devices have the same transmit/receive characteristics. So while several devices will work at a certain distance, not all will.
Apr 12, 2014 | Computers & Internet
My pc reconizes the targus receiver but i dont think the mouse is transmiting or the receiver isnt picking up signal
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port: (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope it helps you
Jul 10, 2011 | Computers & Internet
Recording to itunes program is muffled and unclear and instead my voice and conversations while i am recording is heard
Sounds like the Record Input is picking the computer's microphone instead of the iT Turntable Source.
On your computer, select Start->Settings->Control Panel
Pick the "Sound" panel item, and bring up the "Sound and Audio Device Properties" dialog.
Across the top of this dialog, there should be several tabs. Pick the one marked "Audio", and there should be a pull-down menu in the middle to select the default Record Device.
Pick the device that matches your USB Turntable device, and try again.
If this helps, please be sure to hit the "thumbs-up" for me.
If not, post a comment back and I'll see what I can do!
Apr 03, 2010 | ION Audio iTTUSB Turntable
My whirlpool LSR7233B will not spin or adjatate
sound's like the couping between the moter and the transmition is bad.to replace the coupling you first to remove the two screw's on the frount of the control panal.than pull control panal forward and lift up and back.next you nead to remove the clip's on the left and right.next unplug wire harness from door switch line.next lift the door and pull body forward and out.the whole body will come off.the first thing you will see is the water pump.remove the two 1/4# screw's from clamp's holding the pump on. next remove the two clamp's.next pull pump forward and to the left to keep it out of the way.next remove the wire harness from motor.next remove the clip's from motor and pull motor out.next remove what is left of the coupling from the motor and the transmition.install new coupling kit.you my have to use a exstention and a hammer to tap new part's on motor and transmition.next place rubber part on transmition and line open hole at 12 oclok.on the moter make sure you have one of the prong's at 12oclok to match the transmition.take the motor and line it up with the transmition and push it on.next reinstale the two clip's to motor.next reinstale wire harness to motor.next realine warter pump with motor.you my have to manualy turn coupling to get motor to line up with pump.reinstall clip's to water pump along with the two 1/4#screw's.next reinstall body on frame and reinstall the clip's to the left and the right.next hook up the wire harness back on the door switch line.next rotate control panal down and set in place and reinstall the two screw's and you are done.
Nov 17, 2009 | Coffee Makers & Espresso Machines
I have no voice on my navigation
check to see if you have fm transmit on turn it off.
also for voice guidance you need to pick a voice with tts(text to speech picked) emily(tts)
Michael
Aug 14, 2009 | Garmin nuvi 750 GPS Receiver
Bluetooth has stopped transmitting
Make sure your version of bluetooth for the hand held device and the listening device is not an old version. The first generation of blue tooth was able to transmit sound (for phone calls), but not able to transmit stero sound or mp3.
Sorry I couldn't be more helpful... :)
Dec 11, 2007 | RIM BlackBerry 7100G Smartphone
Radio Shack Pro-2096 Base Scanner Logo
47 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
