Question about Toshiba 44NHM84 44" TV
Shadow down right side of screen on a toshiba 44NHM84 44" DLP television
I have seen this problem on the internet but never a solution. I have a 5" wide shadow down right side of screen on a Toshiba 44NHM84 44" DLP television. The set is barely a year old. It happened overnight one day and has been like this for about 2 months. You can still see the picture through the shadow. Any ideas?
  • 3 more comments
  • soccrb182 Dec 12, 2007
    I just noticed the same issue. Switched from the Xbox360 over to satellite and there it was....a nice shadow down the right side of the screen. Let me know if you here of a solution!
  • pat -t Jan 03, 2008
    Have a 8" shadow down the left side of the screen. Set worked well for over a year but then developed this problem over night. Saw on one of the forums that it could be related to a problem with the light engine. called the local Toshiba rep and found out that to replace the light engine would cost almost as much as I paid for the set. Any solutions?
  • dan-o-might Dec 04, 2008
    I"ve had about a 4-inch shadow on the right side of my screen for over 2 years now. One day it just appeared. It's not dirty. I suspect the mirrors or the color wheel inside may need to be adjusted, i've been too worried to open it up myself
  • Four Leaf Jan 23, 2009
    I had the same problem while under warranty.They changed the engine.The tv is still a piece of $h!t.
  • Anonymous Mar 25, 2009
    I have the same problem on my RCA dlp television...please advise
Shadows at the bottom of the screen sound like moisture that was "wicked up" between the screen layers and dryed out leaving a stain. DO NOT get these screens wet, use nothing but a damp soft cloth; just a few drops of water running down the screen can cause a fairly large stain. Some people have suggested that they may be professionally cleaned, but the risk of damage is too great on the user level.
Posted on Nov 23, 2008
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Toshiba 37WLT66 LCD TV screen has a grey shadow verticaly down left side.
I have a Toshiba LCD TV .a very light shadow on the screen just to the right
Dec 14, 2009 | Toshiba 37WLT66 37 in. LCD Television
I have a SamSung HL-S6187W DLP whide screen tv
You need to replace the light tunnel.you will need to remove the lamp and color wheel along with the lamp housing and fan housing to replace it .If you are not comfortable taking things apart you might want a tech.
Nov 30, 2009 | Televison & Video
I have a 46 Toshiba DLP television
Hi,it does sound like it could be that mirror since thats what direct the light of the lamp.You will need to replace the light tunnel.
Oct 05, 2009 | Toshiba Televison & Video
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Shadow down left hand side of screen
Is it an LCD or DLP? The Model below suggests it is an DLP. Sounds as if you have the dreaded light tunnel collapse common to all LG DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) as LG have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps. Good Luck.
Jul 30, 2008 | LG RU-44SZ51D 44" Rear Projection...
Three inch shadow running down on right side of screen
Light Tunnel needs replacement.
Web page describes:
http://calgaryconvergencerepair.weebly.com/samsung-light-tunnel.html
If you are in Calgary, Alberta, email me.
If not, look at the repair person finder at Homepage of the Fixya site.
This is only for the Samsung DLP, comment is not indended for the other makes listed below the problem.
easyab
Jun 27, 2008 | Televison & Video
Toshiba dlp
Sound like you light engine is going bad. A major problem to fix! Especially if you are sure it is a dlp
Jan 07, 2008 | Televison & Video
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Toshiba 44NHM84 44" TV Logo
387 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
