Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
LTV-32w6 won't turn on
I have a ltv-32w6 HD westinghouse LCD TV. It won't turn on.I took it apart to check for a blown fuse. I found one on the powersupply. The problem is every time I replace the fuse it just blowsagain trying to turn on the TV. Does this sound like a bad inverter,power supply, or something else?
  • 1 more comment
  • tami924 Nov 24, 2008
    Did you find out what it was , I have the same problem.
  • Anonymous Dec 17, 2008
    Same problem, almost made it two years then nothing.
  • klzeplze Dec 22, 2008
    ltv-32w3 32inch froze picture even when i changed channel on cable box had to unplug to turn off now wont turn on made in mexico
Were on the power supply is the fuse located
Posted on Nov 13, 2008
Why doesn't it stay on channel?
Gustav, Try factory reset, to get to the Setup Wizard. With the TV on press the menu button on your remote. While the menu is displayed press the 0 button four times. This should bring up a new menu with factory reset as an option.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.hdtvsolutions.com/pdf/27w7_32w6_37w2uMan.pdf
Westinghouse LTV 32w6 User Manual
How do you factory reset Westinghouse lcd tv AskReddit
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/678671-new-offical-westinghouse-ltv-27w7-ltv-32w6-ltv-37w2-thread-87.html
Mar 12, 2016 | Westinghouse LTV32W6HD 32 in. LCD...
Vertical color lines wont stop running while audio is good.
Westinghouse SK-32H240S Problems Anyone? - AVS Forum ' Home ...
www.avsforum.com/.../1143881-westinghouse-sk-32h240s-problems-an...
May 2, 2009 - 30 posts - ‎18 authors
I have owned my Westinghouse SK-32H240s for about 18 months now, and I ... Youwon't be certain if you are getting the right firmware or the complete firmware. .....makes it stop for a while, the same as it may with a weak antenna signal. .... would just go nuts and display a bunch of colored bars vertically.
Roku Forums • View topic - Westinghouse LTV-32W1 HDMI problems
forums.roku.com/viewtopic.php?f=28&t=27628
Apr 28, 2010 - 15 posts - ‎8 authors
I have a Roku HD box and a Westinghouse LTV-32W1 tv. ... Any idea on why it won'tconnect to the roku correctly? ... This does nothing to stop evil people from stealing movies, but does make ... but it is just a bunch of lines and colors all stretched every way. .... all running wireless on a actiontec C2000A.
Westinghouse LED TV LD-4655VX Fix - YouTube
? 24:48
https://www.youtube.com/watch?v=N_zPWgEitjE
Aug 7, 2013 - Uploaded by TipsNNTricks
Your Westinghouse TV Parts Here: http://amzn.to/14ETOTN ...LED LCD TV FIX, How To For Samsung Double Image, BlackVertical Lines, Screen ... Samsung TV Won't Turn On - How to Repair Bulging Capacitor for ... Problem with Westinghouse LTV-32W6 - Duration: 5:09. by toddalex4 20,284 views.
Dec 19, 2015 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Tv has sound but picture only stays on for a few seconds
Since this is not CRT TV, error codes above is not applied to this LCD TV.
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Check to see if you have 24vdc at the inverter board fuse as shown in the picture, the problem can be the inverter board or power supply board.
PARTS: http://www.shopjimmy.com/catalogsearch/result/?q=westinghouse+LTV-32W1
May 12, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Tv turns off and dont want to turn on again
check outlet power by connect other device, check power cord if OK check then unplug tv and open the back cover and check power filter fuse power filter is the one that you hooked power cord if OK check power supply board fuses if OK check the power supply board for bad blown components .good luck
Apr 29, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
After about 2 or 3 hrs my Westinghouse 32'' LTV-32w6 screen starts to turn into line like the picture is all grainy how do i fix this problem?
Does it look like this? http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
You may have LCD controller board overheating problem (the pictures show the board with shield removed)
Try cooling it with small fan blowing at the vents.
Mar 28, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My Westinghouse LTV-w1 will not turn off. None of
try unplugging tv to reset it,leave it off for a minute,and then plug in
Jan 08, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sound cuts out in Westinghouse LTV-32w6 HD TV
is it ran through a HDMI cable?
sometimes the source is at fault or it could be a bad hdmi cable or maybe a bad hdmi port. if your using a hdmi try plugging it into another hdmi port and see if that helps
Jan 06, 2018 | Westinghouse Televison & Video
My westinghouse lcd tv ltv-32w3 hd
I had the same problem these LCD TV's are designed poorly and have very little ventilation my warranty was up so i took it apart and installed cooling fan have no problems what so ever now.
Jul 18, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
1,193 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
