Question about Acer Aspire 5100 Notebook
Acer Aspire 5002 WLmi heat sink location
Hey Josh,
This is Ravi. I have Acer Aspire Laptop and the middle portion on the bottom of the laptop heats up super bad. I opened it up to find that its a silver box like thing with slots in between. Is that the heat sink? How can I remedy the problem. The CPU temp when CPU intensive work is going on is in the range of 55 to 65 C. The CPU is not as hot as the heat sink though. Any suggestions/help is much appreciated.
You can contact me at ravi.hasija@gmail.com.
Thank you for any help that you can provide.
Not sure if you've tried one of those cooling pad, i've used one on mine and it does seem to help. You can pick them up for about $20.
Posted on Nov 16, 2008
I need acer 5002 wlmi laptap drivers how to download acer web site not privided
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed.
I'm Ben and -- hopefully -- I can provide some meaningful assistance.
Click on the following link and download the drivers for your Acer Aspire 5002WLMI. CLICK HERE
May 24, 2012 | Acer Aspire 5002WLMi Notebook
Acer Aspire 4930 heats up very quickly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 28, 2012 | Acer Aspire 4930-6862 Laptop
I have acer aspire laptop. whenever i play any videos or movies my laptop suddenly shut downs. plz let me know whats the problem
uninstall your flash player ,,, and download a fresh copy from the adobe site ,,, if the problem persists check out the cpu fan and the heat sink ,,, clean the fan and the sink and apply some heat paste ,,,,
Mar 06, 2012 | Acer Aspire 5610-4648 Notebook
My acer 5720 laptop gets v hot and shuts down i sit it on a coolin pad already. what could the problem b it seems 2 hapen more often when the power cable is in use and only rarely when the batery is in use
This is a common problem in the acer line, remove bottom and clean all the open ports and fins on the heat sink and fan. Next remove the heat sink and clean the old conductive paste off, including the processor ic with rubbing alcohol, now! apply fresh conductive thermal paste to the heat sink and ic, this will increase the heat dissipation by 50%, and check to make sure the fan is running properly, "high failure rate" this should solve your shutdown problem.
Mar 26, 2011 | Acer Aspire 5720-6661 Notebook PC
Need windows xp 64 bit drivers for acer aspire 5002 N WLMi. it's not privided with the cd
http://support.acer.com/us/en/product_support.aspx?tab=1 Click on the link above and select your notebook from the product list and the drivers will be available for download.
Dec 28, 2010 | Acer Aspire 5002WLMi Notebook
My 5002 WlMi won't boot. All that happens when
Replacing a motherboard on a notebook is generally only recommended for professional technicians. As a last resort before trashing it, it might be doable for a resonably skilled person, but finding/buying the right motherboard is another matter.
Though, it might not be the case that it's the motherboard that's faulty.
If you can post a more detailed description of the problem, when it occurs, and if there are any life-signs at all (HDD-lights, screen, fans et.c.) it might help getting some answers.
Apr 11, 2010 | Acer Aspire 5002WLMi Notebook
Acer laptop gets very hot inside fan is running but still hot ?
Your heat sink vents may be jammed up with fluff and other debris.
If you're not comfortable removing the bottom pannel and using some canned air to clean out the heat sink fins, I would take it into a repair depot and have the techs there apply a new application of heat sink compound and clean it out for you.
Jan 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
My brand new acer aspire 5515 laptop keeps shutting down
Return it for service. This is a defect. The fan should run until the heat is below the temp threshold.
Jan 01, 2010 | Acer Aspire 5500 5570-2609 Laptop
Laptop shuts down shortly after boot up
this looks like heat issue...varify that the cpu fan is working.....apply heat sink cream on the cpu surface and the heat sink
keep me posted
May 13, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5100 Notebook Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
