Question about Toshiba Televison & Video
Hi, I bought a RD-XV48 VHS/DVD REcorder with Freeview and a 160g Hard drive and Time slip. The problem is I can not understand the manual all I have done is connect to the TV with HDMi lead, I can Record on a DVD from the TV and play DVD's but I can't understand or use the VHS Recorder or use the Time slip, I haven't got a clue I need instructions blow by blow really . Help is what I really need
  • recordman Nov 13, 2008
    Thank you I will ofcourse do as you say but I thought if I used a HMDI LEAD I did not require the coloured leads at least that's the way I understood it.
    How many leads do I require and what are they called
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Click this link for fix your problem...
http://hometheater.about.com/od/dvdrecorderfaqs/f/dvdrecgfaq17.htm
Thanks
Good Luck
Posted on Nov 13, 2008
  • 1,879 Answers
Recording to the VHS Recorder is the same as to the DVD Recorder.
    President:
  • 2,712 Answers
Yes, I know how some manuals can actually confuse more than explain details...
However, it would be near impossible to explain all details here. The simplest solution would be to just go back to the store and have the sales person explain to you how it works, connections, etc. Thats the honest truth..
  • 734 Answers
Does this connection output all formats? ie VHS, DVD & HDD? and allow upscaling? or does the VHS have to output via the SCART?
  • futureloginn
    futureloginn Nov 13, 2008
    2 HDMI OUT jack (HDD/DVD)• Connect to a display with an HDMI compatible
    port. Use a commercially available HDMI cable
    Genius:
  • 1,550 Answers
This link will provide you some details regarding connection of vhs recoder
VHS recoder connection
While playing vhs tape, the sound is great, but the picture comes and goes.
That's usually dirty or worn out heads or not enough take up tension in the tape
Sep 27, 2014 | Toshiba RD-XV49DT DVD/DivX/VHS...
Toshiba RDXV59DTKB
You might have accidently set it to one of the special sound settings such as dolby or DTS. Bring up the main menu and look for the sound menu.
Jun 24, 2014 | Toshiba RD-XV50KF DVD/VHS Player/Recorder...
I have a recorder that whenever i put in video cassettes stops playing after a few seconds and turns the unit off. Can anyone help. Thanks
sounds like belts and rollers and any sensors you see need to be cleaned - it sounds like the unit thinks tape is at end and is shutting down
use qtip and rubbing alcohol to clean
try using different tape just to make sure it is not just a bad tape
Mar 21, 2011 | Toshiba RD-XV49DT DVD/DivX/VHS...
Is third time a charm. Again several years ago I
Here is the owner's manual for your DVD machine. This is a VHS recorder but not a DVD recorder. To record VHS tapes to DVDs, you will need a DVD recorder.
You will plug the yellow video out connector on the VHS to the yellow 'Video in' connector on the DVD Recorder. Do the same for the red and white audio connections, out on the VHS, IN on the DVD Recorder. Connect your TV to the DVD recorder so you can see the picture you are recording.
Mar 31, 2010 | Televison & Video
I need a user manual for a Toshiba RD XS 25 DVD Recorder
Go to tesc.toshiba.co.uk select "customer access" on bottom left, then select what model, etc and there you go.
Mar 12, 2009 | Toshiba RD-XS25 DVD Recorder/HDD Recorder
Unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Jan 03, 2009 | Daewoo DVRS04 DVD Recorder/VCR
HELP
I am trying to set the timer record to channel 185, but my unit will only allow me to set to channel 125.
Apr 15, 2008 | Toshiba DR550 DVD Recorder
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Televison & Video Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
