Dell Latitude D600 Notebook Logo
Posted on Nov 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a dell latitude laptop, all was fine when the next moment my computer completely switched off. On restarting it, I noticed the battery light flashing orange:red - or is it green:red continuasly. If I disconnect the AC cable the computer shuts down immediately. When selecting the battery icon on the right hand side (bottom) of the computer it shows battery 0%, when I double click it shows me online, critical. I am under the impression that the battery is not charging at all. how do I correct this?
Walter H Boehm
Level 3:
  • Dell Master 998 Answers
  • Posted on Nov 12, 2008
Walter H Boehm
Dell Master
Level 3:
Answers
998
Questions
0
Helped
340962
Points
2289
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
3answers
How to activate bluetooth using wireless switch
Step 1 Find the wireless switch, located on the front of the E5400, to the left of the touchpad.
Step 2
Slide the wireless switch into the "On" position to enable wireless radio communication on the Latitude.
Related Reading: How to Turn on Wireless on a Dell Latitude Laptop
Step 3
Click "Start ' Control Panel ' System and Maintenance ' Device Manager." Double-click "Bluetooth Adapters."
Step 4
Right-click the Bluetooth driver and then select "Enable" from the context menu, if available.
Step 5
Navigate to the Dell Support website in a Web browser if the Bluetooth Adapters category is not listed in Device Manager.
Step 6
Click "Start Here," then "Drivers Home." Click "Choose From a List of All Dell Products," then "Continue."
Step 7
Click "Laptops," "Latitude," then "Latitude E5400." Choose your operating system from the associated drop-down menu.
Step 8
Expand "Network." Click "Download File" next to the Bluetooth driver, then "Download Now."
Step 9
Launch the EXE file when the download completes. Follow the on-screen instructions to install the Bluetooth drivers to the computer.
Step 10
Restart the Latitude following setup to begin using Bluetooth on the E5400.
2answers
How to restore setting on my laptop dell latitude d410
Restart the computer and as it is restarting Press F11 and follow the on screen instructions. If this does not work then one, change is necessary which is, as the computer is restarting ,Press F11 and CTRL together and follow the on screen instructions. Some times the key combination is different so try F10 if the above does not work. good luck
Hi, I have a dell latitude d531 laptop, and today i pulled it out and plugged in the power adapter and pressed the on switch and nothing-not a flicker, no BIOS, not one led flashed. totally dead...i...
Call Dell customer Support Number 1-800-204-4427 if your dell laptop, computer, printer and tablet facing technical problems. Our dell technical support experts will help you out within no time.
Dell Technical Support Phone Number 1 800 204 4427 USA Canada
1helpful
I own a Dell Latitude XP2 Tablet Notebook. It has been working fine for over a year until recently. Now it's been freezing on me after a little bit of use. Sometimes I can use my computer for about 15...
the light next to the Battery LED is the hard drive activity LED (HDD, Battery, Wifi, Bluetooth)
http://support.dell.com/support/edocs/systems/latxt/en/html/about.htm#wp1206073
Off hand, I'd say overheating is a possibility so try using a can of compressed air to blow out the cooling vents and also run diagnostics on the cooling fan (Power plus Fn key to enter diags) If diags finds a hardware issue call Dell Tech
The laptop won't turn on
Hi..
This seems issue with the power supply.
If the computer is in warrenty call dell.
Thanks
Smith
4helpful
Dell Latitude D510 will not charge battery
HI, check soldering on Fuse 1 right next to the power inlet plug, just fixed mine.
you will have to dissassemble it completly to get acces to it
Mains switch on
some shortage inside the computer, go for technical assistace from qualified technician
Power problem
The CPU the next time observe to see if the fan is running......it may not and the CPU is overheating.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
