Question about Canon EOS Rebel T2 35mm SLR Camera
Recurring dead batteries
We have a new EOS Rebel T2. Within a few days the batteries were dead. While we were sure the camera had been shut off we gave it the benefit of the doubt and purchased new batteries (lithium 3v CR2- cost with tax $36.12! These were installed and we made sure that the camera was in the OFF position. Within 10 days we wanted to use the camera and the new batteries were dead!!! It seems to us that the camera is somehow causing the batteries to drain. What could be the problem? What can we do? Sincerely, Roger and Lenore Andrew
  • Canon Master
  • 2,192 Answers
Get it serviced to find out if it is repairable or only insert battery to use then remove when not in use
Posted on May 10, 2017
  • 36 Answers
SOURCE: canon eos rebel t2 battery indicator
guido462:
new batteries - brand new? fully charged per spec?
Posted on Jan 25, 2008
  • 18 Answers
SOURCE: Eos Rebel 2000 battery problem
Send camera to me and I will advise you B4 repairs regarding cost etc. WWW.FLCAMERAREPAIR,COM Art Schneider
Posted on May 01, 2008
SOURCE: low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
Posted on May 13, 2008
  • 44 Answers
SOURCE: no power when battery was replaced
I have found some variation in how long the CR2 batteries are. You might try bending the negative contact up to give more pressure against the battery.
Posted on Dec 12, 2008
pontelemon
  • 538 Answers
SOURCE: Cannon EOS Rebel G battery light
Film Advance mechanism is jammed and needs service.
Posted on Apr 09, 2009
How to replace clock battery in eos rebel ll
your "clock battery" is just a very little rechargeable battery, that will charge as soon as you put in a fully charged battery in your camera. You should wait for at last 12 hours, before you remove the battery. and the little battery can keep the clock running for several days.
Everything that is in the camera, only can be replaced by a skilled electronics engineer. The best thing you can do is contact a certified Canon repair centre and ask what it will cost to build in a new clock battery. But before you think it is a clock battery, make sure your battery is still in working order. Ask around if anyone you know has the same camera and borrow a charged battery for a few moments, to make sure it is not you camera battery.
Apr 19, 2014 | Canon EOS Rebel G 35mm SLR Camera
Canon EOS Rebel T2 - film loaded, but then wouldn't take a picture, the frame count was flashing on screen. What is the problem?
Hi. Open the camera back and pull the film further over towards the pick up spool, close the back and try again to take a photo, i had the same problem with an eos 650 and it always worked.Good luck.
Apr 15, 2014 | Canon EOS Rebel T2 with 28-90 lens 35mm...
When I take videos with my canon rebel, it stops recording after about 30 seconds. Do I have some settings set incorrectly?
If you are shooting video then you must have the Canon Digital Rebel T2i as the Rebel T2 is a film camera. Anyway I've checked through some data and your camera is capable of 29 minutes 59 seconds of video before shutting down due to heat. I would expect that your memory card is not a Class 6 or faster if it is then you may have forgotten to format the memory card to the camera it is being used in.
Jan 22, 2011 | Canon EOS Rebel T2 with 28-90 lens 35mm...
How long has this camera been out? I'm shopping
HI,
The Canon Rebel T2i was announced on Feb 08, 2010 and Canon just started shipping the DSLR. Your salesperson was thus correct.
The DSLR is also known as EOS 550D. It differs from the previously model by:
  • Higher resolution 18MP CMOS with gapless micro lenses
  • ISO 6400 no longer in 'expanded' range (12,800 max remains the same)
  • Redesigned buttons and new movie/live view button
  • Customizable auto ISO ranges
  • Improved 63 zone metering (iFCL)
  • 3:2 format screen with more pixels
  • Improved movie functionality
  • Slightly higher burst shooting rate (though buffer holds fewer shots)
  • HDMI control (CEC)
  • SDHX Compatible
  • Apr 08, 2010 | Canon EOS Rebel T2 with 28-90 lens 35mm...
    Pictures too dark
    Check your exposure compensation. It really sounds like someone set the camera to underexpose. This may be solved by removing the batteries for a few minutes. Other solutions are hitting the reset which will cancel all and return it to factory settings OR navigate to the exposure compensation settings and reset it there. If none of these solutions work, then the camera's internal program is messed up and its internal computer needs replaced.
    Dec 17, 2008 | Canon EOS Rebel T2 35mm SLR Camera
    Low battery warning
    May 10, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
    Canon eos rebel t2 battery indicator
    guido462:
    Jan 21, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
    Oct 18, 2007 | Canon EOS-AE-1 35mm SLR Camera
    How to set camera up for lighning shots
    You can download the manual from the link below: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=313&modelid=10466 Please update the question & let us know if the information given was useful to you - Good Luck!
    Sep 05, 2007 | Canon EOS Rebel T2 with 28-90 lens 35mm...
    Canon EOS Rebel T2 35mm SLR Camera Logo
    Top Canon Photography Experts
    old marine
    old marine
    David Payne
    David Payne
    Jerry Greenberg
    Jerry Greenberg
    Are you a Canon Photography Expert? Answer questions, earn points and help others
