Since this error occured, the camera has been taking hazy pictures, takes upto 5secs on turning on, displays "PROCESSING " for 2-5secs while the picture is shot and the display seems hazy, not sharp.
SOURCE: sony cyber-shot dsc-w55 flash doesnt work
hi
the flash doesnt flash anymore, you may need to replace th bulb for that. the yellow light means its a warning that the bulb is wor out.
hope this helps
SOURCE: Sony Cyber-Shot DSC W30 - says "ACCESS"
I fixed the problem that I reported above by physically pulling the lens out with my fingers as the camera tried to do it itself. It took a few tries, but eventually it came out. Power on the camera and pull the lens housing outward. I think I will have to repeat this occasionally, but I haven't used the camera much recently. The lesson in this is do not lend this camera to an 8-year-old.
SOURCE: format error on my sony cybershot dsc-s730
Format error comes because memory stick has an error. Please format memory stick by going in to Menu>> format>>OK
If error still comes then memory stick is bad and need to be replaced with new one.
SOURCE: I have a Cybershot DSC-S780
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
SOURCE: Sony Cyber-Shot DSC-T1 Digital Camera is taking weird pictures?
imager is going bad due to moisture. try using hair dryer to dry it out. if not flat rate to sony is around 120
is your camera battery is in a normal working condition?and whether your camera len is stucked
http://www.digitalcamera-parts.net/
e-mail:[email protected]
