Question about RCA VR555 VCR
Commercial Advance feature shuts off vcr.
Taped show. While watching the tape, the show goes to commercial, the commercial advance kicks in and fast forwards, then the fast forward slows down to hunt for the place to begin regular playback, then the vcr shuts down. I turn the vcr back on and it kicks out the tape. This happens with several tapes old and new.
  • 3 Answers
Check the condition of the rubber pinch roller that holds the tape against the capstan post. As the rubber begins to dry out and have less resiliency, it is less able to pull the tape in either direction during the slow speed search movements. (Hint: this also makes the tape rewind almost slow to a crawl as the tape is nearly rewound to the beginning.) If the VCR tape movement sensors see it go slack or too slow, it will trigger an automatic shutdown to protect the tape and the machine. I have been able to clean and apply a "Re-Grip" solution to the roller as a temporary repair. After a while, it will slip again. Replacement of the roller is the best fix.
Posted on Jan 05, 2007
    President:
  • 3,130 Answers
You need to clean the video tape path my freind, or the machine needs an alighnment. you can try to clean it with a head cleaner, and it might work, but most of the time you need to have it professionall cleaned. If you want open this http://www.bealecorner.com/trv900/trouble/cleaning.html, and it is about the same proceedture with a camcorder to clean a VCR, just take off the top cover of the VCR. Good Luck Please do not forget to rate this thread.
Posted on Nov 27, 2006
3 Suggested Answers
  • 2334 Answers
SOURCE: can not tape from cable, blue screen
If you have a cable box connected now, leave the VCR on channel 3 all the time and use the channels from the cable box.
The way this should be connected is cable in to cable box and cable out to VCR, VCR output to TV IN.
Hope this works for you.
Posted on Feb 11, 2008
blindrabb844
  • 3 Answers
SOURCE: Have an RCA VR618HF VCR. Have cleaned the head and
Check also to see if the belt(yes this unit has a single belt as the drive) located between the mechanical ch=arrage and the circuit board has not fallen off or broken in half. This belt drives the forward and reverse hubs to pull the tape along the tape path..
This belt is available from the projector recorder belt company for a few dollars. Getting the carrage to seperate from the circuit board requires a repair manual and some patience.
Hope this helps too. ;)
Posted on Nov 28, 2009
I taped a TV show. But I can't fast forward to see the end part that I want to watch. It just advances to the end.
I'm not surprised that it advances on the end. The VCR doesn't know where the end of the taped programme is. You will have to search manually for it. Start at the end of the tape and rewind a few minutes worth of recording then press 'play' and see what you get. If not successful rewind further and try again, etc,etc. Alternatively you could press "play +rewind" which should allow you to watch the record on what is fast (=x2) rewind. It will help you if you know how long the show was and at what point the tape was when recording started.
Mar 26, 2015 | Televison & Video
Philips vcr VRB612 inside diagram/picture
You will need a service manual for that. I did a search for your model and there is little out there. Some Libraries stock them, often in the main city one in your local area. Some commercial firms such as Manuals Paradise also do them, but they would charge you for one, if they have it!
Apr 06, 2014 | Philips Televison & Video
How can i fast foreward commercials with the vcr
If you are watching a tape, simply use the FF button to skip forward until you see that the commercial is over, and then press PLAY to resume playing.
If you are watching a live TV program, the short answer is - you cannot. You need a PVR or TIVO or such device to be able to do that - and even then you have to be time shifted back at least the duration of the commercial you want to skip first!
Jun 22, 2011 | Orion VR213 VHS VCR
Forward fasts on its own
you may want to try fast forwarding at 2x (that is, press the FF key twice), although the speed will be faster, it may actually stop for you, when you press play, rather than going to the end.
Feb 05, 2009 | Arris DCT6200 DTV Receiver
VCR playback sound and pciture don't match
That is a tape path issue. The new VCR has the problem, usually the guide post for the tape sticks out when it shouldn't making the sound late for the picture because the gap between the video head and audio head is wrong.
Mar 31, 2017 | Philips Magnavox 20MC4304 20 in....
My VCR tapes skip or only play in fast forward
If you are recording the tapes in a slow speed, then I would suspect that the tracking pulse is not being recorded properly. Since this is a new VCR, return it for an exchange. One of the recording heads is bad.
Dan
May 30, 2008 | Televison & Video
Recording on a Panasonic VCR
This problem is undoubtably dirty or worn video heads. Try using a good quality head cleaning tape. If this fails, re-post, and I will explain how to clean heads by hand.
Dave Duff
Mar 01, 2008 | Panasonic PV-V4022 VHS VCR
RCA VR555 VCR Logo
147 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
