HP Solution Center Popup
Whenever I turn on my computer, the HP Solution Center Popup shows up, I was going to uninstall it and a warning came up that I would not be able to use my printer. I just bought a new Vista and new all in one printer. How can I remove the popup Thanks!
  • 1 more comment
  • Anonymous Jan 14, 2009
    Drives me Crazy, but mine WAS just at startup, now its every 5 seconds.
  • Anonymous Mar 04, 2009
    I have the same problem: I am using XP Pro and HP Officejet H470 on a Dell Computer
    Several pop ups occur only at startup.
  • crashcup954 Mar 21, 2009
    I've been having the same problem. The solutions I've seen posted here and elsewhere don't make sense - they don't address the underlying issue. Sure, one can uninstall or disable HP notifications in general, but this should not be necessary. What triggered the sudden occurrence of these pop-ups? Someone from HP owes us an explanation.
    Novelist:
  • 148 Answers
Greetings Sheryl,
My name is Mark and I will be happy to assist you. If that pop up is asking for an update go ahead and allow it. HP for some reason needs to update constantly. Here is one other method we can try. If you are running Vista on your computer go to start then right above start is a search box type in "run" and it will appear at the top of the box go ahead and click on it. A new box will appear you don't have to click anywhere just type"msconfig" and hit the enter or return button. A new box will appear this is your msconfig at the top will be some tabs click on the one that says start. another box will open and it will have programs in it with check marks next to them. Look for all the programs with "HP" in the beginning and uncheck them. Now click on apply and ok, it will prompt you to restart go ahead and do so. When it restarts a box will appear stating that "you have made changes to your configuration, there is a small box in the lower left corner that says "do not remind me again", click on that and ok the box. See if this works Sheryl if not contact me again and we will try somethin else.
Be mucho blessed,
Mark
Posted on Nov 12, 2008
I have the same problem, but am running XP pro. Any advice?
JP
Posted on Nov 21, 2008
Printer has worked fine until now popup says
If you reboot your computer and the print spooler will not stay running you can go to the HP website and download the newest drivers. You can try to run the software before you unplug but I normally unplug the printer uninstall the printer drivers and software.
Then install the new drivers you downloaded before you plug the printer back into the computer.
Mar 08, 2010 | HP PSC 2175 All-In-One InkJet Printer
How do I uninstall the program software for HP OFFICEJET PRO L7500 (have installed a copy by mistake) on Windows Vista
Go to Control Panel - Program Updates- Locate the program in the list then click on it and select uninstall from the popup window.
Oct 07, 2009 | Microsoft Windows? Vista Home Premium...
No HP devices detected. HP Solutions Center will close now.
Whenever this problem comes up in the future and the printer is not showing in the control panel,you need not uninstall the whole printer s/w,but instead you can insert the CD and then click on add a device,it sometimes happens that printers take a dynamic IP address and do not show up.f you want further support you can avail free online technical support on http://tinyurl.com/m7ghqz
Jun 14, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Wireless assistant not working, light staying orange
Window Vista- Go To Control Panel, then go to Mobile PC, then Window Mobility Center, then go to the top right of the mobility center and click on Turn Wireless On
May 27, 2009 | Microsoft Windows Vista Home Premium...
HP Solution Center No HP Devices Detected
Try this
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F2100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Jan 03, 2009 | HP Photosmart C8180 All-in-One InkJet...
I just purchased Vista Computer, Solution Center Popup keeps coming up when I turn on my computer. I have a 4 in 1 printer and when I tried to remove the Solution Center, a warning came up that I will...
Hi Sherylpus,
Congratulations on your new PC! Its always so exciting until your printer doesn't work eh? :)
OK down to business. I am going to need a few more pieces of information in order to help you.
What is the make and model of your printer? (you can usually find it in front for example HP 7960, if its not there then try the back or bottom of the printer)
Is it a new printer? or did you use it with your old XP system?
How is it connected to your computer? USB wire? Ethernet cable? (Ethernets like a big phone wire)
Has it ever worked with your new vista pc?
Have you ever had troubles like this before with this particular printer?
thanks in advance for answering my questions, I'm her to help you
Nov 12, 2008 | Computers & Internet
I have a hp psc 1315 all in one. unable to print or copy. after checking various troubleshooting efforts which were not successful, I attempted to print and a popup displayed showing the print spooler...
click--start --onleft hand corner of your pc go to --control pannel--select --perfomance and maintenance---click the icon ---system -
select the option --data execution prevention--there select--turn on dep for essential windows program and services only-- and then select the spooling option through tick mark just click it will appear. if this does not support then do this,
do this if you have the installation cd
uninstall the printer and re load again the printer drivers
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Aug 08, 2008 | HP Office Equipment & Supplies
Says i have a popup blocker installed and i cant uninstall it
try going to the tools menu in your internet browser go to internet options there should be an option there to turn off pop up blocker
Jun 03, 2008 | Computers & Internet
Shows it's offline
Hi,I was working for HP as Sr. tech support for 18 months in All in One printer Department, newly joined at Fixya to test my technical skills.
Step 1.Unplug the USb and reconnect it.
Step 2.If that doesnt works, right click on the printer ICOn in the control panel ->Printer and faxes.Check whether do u see "use printer Online".If u see it click on it and then check the printer,If it doesnt works or If u dont see the option "Use printer ONLINE".Go to Step 3.
Step 3:
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F300)
Thank you.
Feb 09, 2008 | HP Deskjet F340 All-In-One InkJet Printer
MS Access popup forms
Most forms open by default to the last size they were. If you can resize one of them by dragging the border, see if it still opens minimized. Or open the form itself, rather than invoking it from the switchboard, and try resizing there.
Jan 31, 2008 | Microsoft Office Professional 2007 Full...
6,345 people viewed this question
k24674
