Question about Singer 7462 Mechanical Sewing Machine
Timing/tension on a Singer Merritt 3014
I'm trying to adjust the tension (I think that's the problem) on my wife's Merritt sewing machine. Anyone got a manual or advice?
SOURCE: singer merritt 8834 sewing machine slows then stops
If you still need the Manual E-mail me @ goldengoose001@yahoo.com be sure to put in comment part of e-mail something Like "Looking for a singer 8834 manual" as I delete all e-mail without reading them unless I know the person or what e-mail is about and know its safe , and even then I scan all and report any found to have viruses , etc
Posted on Aug 15, 2008
  • 67 Answers
SOURCE: I need a manual for Singer Sewing Machine Merritt Model 9444
goto : http://www.brewersewing.com/Stockimages/Parts_manuals/special/sewing_parts_manuals/9444.pdf
Please rate this solution well, it is a direct link to a PDF image of the manual you requested.
Posted on Jan 23, 2009
SOURCE: Need a manual for Singer Merritt 9612. to download if possible.
Try
www.singermachines.co.uk/Parts_&_Ser/indstbooks.htm - 107k -
Posted on Mar 31, 2009
SOURCE: Singer/merritt 2430 bobbin fill
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
Posted on Jul 08, 2009
bargainbox
  • 1388 Answers
SOURCE: Problem with tension on singer tiny tailor mending machine
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Aug 30, 2009
Should I trade my Singer Merritt 3130 for Brothers JX2517
A: You asked, "Should I trade my Singer Merritt 3130 for Brothers JX2517". Ultimately, it is up to you, as to whether you prefer the more vintage aspects of the Singer-Merritt 3130, or the sewing feel you get from the newer Brother JX2517. If you have been sewing on a Singer-Merritt 3130 which is in proper adjustment for some time and you are used to the sound and feel of this heavier machine, I think you will have more than half the answer already.
However, do compare your Singer Merritt 3130 it to the Brother JX2517. Though I have not used that particular model Brother, I have sewn on several modern "plastic" Brothers, that all sewed very well (most Brothers are great machines), but were all much louder and more rattly than the three Singer Merritt models I own (two Models 4552 (the first one I owned quickly became my favorite GO-TO machine for most tasks) plus one more modern "plastic" Singer Merritt 9618, that I was quite impressed with too, though it is a different ball game.
The Brother JX2517, looks as if it has a lot of bells and whistles, and does 17 stitch patterns and a 4-Step Buttonhole; it might be OK for you, but you must do some sewing tests with both. Because this Brother it is a modern machine, it won't take much maintenance, but if something goes wrong you probably will not be able to fix it yourself, and will need to take it into a repair shop (where, unfortunately, they may just want to sell you the next new model they have in stock).
When it gets down to really sewing, the added fancy stitches will not matter to you at all. What you will want is a machine that lays the stitches down where you want them, predictably and reliably without missing a stitch, jamming or fouling. Try them side by side without the pressure of a salesman standing over you, nibbling your ear and praising the new machine and pointing out the limitations of your old machine. Test sewing on very thick folds of denim and also on very thin layers of cotton, rayon or even silk, but mostly test the type of stuff you usually sew. Look closely at the stitches, if either machine does not produce nearly perfect stitches, then you cannot make a decision right then, that is not until both have been properly adjusted to sew nearly perfect stitches (which I am sure both can be so adjusted). Only when both machines are sewing at their best, can you really compare the two for the finer details.
Try closing your eyes to just "Listen" and "Feel" each machine as it sews, but don't get your fingers caught ! Which machine would you enjoy sewing with in the long run. The answer should be clear, but if not, there is always another option.
ALTERNATIVE: If you are still not sure which is better for you, and if you are still hell-bent to buy yourself a new toy, then don't "Trade In" your Singer Merritt 3130, but instead Bargain with the Salesman or Owner, to get them to give you the "Trade-In Discount", without giving up your old machine. I did this on a new Singer CG590, but be careful, you may end up with more sewing machines than you have room for. Keep sewing.
Sincerely,
-- Amender (2016 FEB 24)
Jan 26, 2016 | Singer Sewing Machines
Where can I find a tension assembly for merritt 9606
There is one for sale on eBay right now for $12.99. http://www.ebay.com/itm/Singer-Merritt-Sewing-Machine-Replacement-Tension-Assembly-Model-2404-/151468509588?pt=LH_DefaultDomain_0&hash=item23443a0994
Jun 30, 2014 | Singer 20U73
Merritt 9618
You will find the parts list most helpful, because it will show you with drawings where each part is supposed to go. Go to the Singer site, and type "parts chart" in the Search box, then select Sewing Machines and the 9 - 900 series. Scroll down; it's towards the bottom.
Jun 26, 2014 | Singer Sewing Machines
What size needle for Merritt singer 3014
I could not find a Singer Merritt 3014 nor a Singer 8280. Do you have the serial number and/or model number? You can always try this site:
http://www.singerco.com/products
Jun 11, 2014 | Singer 8280 Mechanical Sewing Machine
Sewing machine merritt 6125
You can order a printed one from your Singer dealer.
Feb 26, 2014 | Singer Sewing Machines
How to thread singer merritt 3130?
Do you have a manual? If not, you can download one from singerco.com. It sounds like the top tension is too loose. Lowering the presser foot will engage the tension disks. The tension disks are located behind the needle thread tension dial. Slowly lower the presser foot, watching the tension disks press together. The thread passes between the tension disks around from the right, underneath and back up to the take up lever. The manual will tell you the location of these parts.
Mar 18, 2013 | Sewing Machines
Singer Merritt 3015 Tension
the tension dial may be going out & need to be replaced at a sewing machine repair shop
May 20, 2012 | Singer Sewing Machines
Adjust timing on Singer Merritt 4530
what size replacement needles for a singer merritt 4530
Oct 21, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
231 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
