Question about Canon PowerShot A540 Digital Camera
White stripes when i take a photo there white stripes all over the photo, that happens too when i want to look at the new photo and on the computer too. i dont know what happened.
    Champion:
  • 225 Answers
This is a problem with your camera lens. Either the digitizer, or the shutter. Either way you will need a new lens, or camera circuitry.
Posted on Nov 13, 2008
Fuji finepix 5600 white stripes
When you say 'played back', do you mean viewed on the camera screen, or after downloading to your computer ? If the latter, it could be to do with the software you are using - try FastStone.
Apr 18, 2017 | Fuji FinePix S5200 / S5600 Digital Camera
When I am playing a game the screen will suddenly go to black and white stripes and the only way to fix it is to restart the computer. It happens about once an hour
the main be a loose ribbon connector at the board. thdis will require a tech to look at it, Usually white stripes and going black on laptops is loose connectors.
Aug 07, 2010 | Dell Inspiron 1501 Notebook
Wire order in new clip to replace broken end end 10 base T
From left to right:
1. White/Orange stripe
2. Orange/White stripe
3. White/Green stripe
4. Blue/White stripe
5. White/Blue stripe
6. Green/White stripe
7. White/Brown stripe
8. Brown/White stripe
Hope this helps!
Aug 07, 2010 | Unicom UTP Network coupler (ILC-S504C-SH)
When I turn the camera o a red stripe with white
Some cards have a lock tab on them. Make sure it is not in the lock position. If no go then take the card to a photo place and see if they can read it and download your photos. If that does not work then you can reformat the card (you will lose your photos). If you still are experiencing problems, try another card. If that does not work then it's off to the warranty repair or time to get a new camera. Repairs on these are only worth it if they are free or really cheap.
Jun 20, 2009 | Casio Exilim EXZ75 Digital Camera
Last month screen completely filled with gray and white stripes running from top right to bottom left. Turned off, and restarted. This happens several times weekly, whether on internet or not, using...
That is most likely the wrong video card for that motherboard. Or the video card slot on that motherboard is faulty... I would recommend taking it back to the shop and letting them fix it, since this happened after you got it back from the shop...
May 14, 2009 | HP vs17
Casio Exilim EX-Z60 used very little. All photos very messed up!
the shutter is bad in low light it will have banding stripes in bright light it will be white . must repair shutter or replace.
Apr 14, 2009 | Casio Cameras
Replaceing phone wall plate
Hi Leanne!
Normally the conductors in phone cable are colored green, red, black and yellow in older style wiring. Green and red are used for a single line, and black and yellow are for a second line. Newer systems use wires that have conductors twisted together in pairs. White with a blue stripe paired with solid blue or blue with a white stripe is line 1. White with an orange stripe paired with solid orange or orange with a white stripe is line 2. (At least this is true in the US. You said "cheers" so maybe you're not in the US and the color coding's different.)
Chances are your line is using the blue and white wires.Residential telephone equipment isn't polarity sensitive so it really doesn't matter which wire you hook to L+ and L-. Try the white/blue combination first. If you don't get dialtone then try red/black. If still no luck you only have two more combinations to try.
Before you start with the wiring, take another phone on the line off the hook (if you have another one). This will prevent an incoming call from ringing the line, which can give a shock if you happen to be touching a bare end. The ringing voltage is much higher than the normal phone line voltage which won't bother you.
Apr 11, 2009 | Lands Phones
Printing 5X7 photos
try aligning and cleaning the cartridges
hope this helps
Apr 12, 2008 | HP Photosmart 2575 All-In-One InkJet...
Blank stripes on page left to right
If the blank stripes go up and down the page (vertical) then it sounds like the laser lens has simply got toner on it. remove the toner and photo conductor units. Look for the glass panel that covers the laser lens and simply wipe it off with a cloth. Some machines incorporate a lens wiping pad that can clean the lens without taking out the parts. I can not remember if the 1710 does or not.
Sep 06, 2007 | Samsung ML 1710 Laser Printer
Canon PowerShot A540 Digital Camera Logo
96 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
