Question about Kenmore 22612 Bagged Canister Vacuum
Kenmore Canister 116.20712007 replace power cord
Prong broke off plug and I need to replace the entire power cord on my kenmore, model number 116.20712007. I've ordered the spare part from searspartdirect.com and will have it soon.
Any advice on replacing the power cord will be swell. I've heard its pretty easy to do.
  • vkolli Feb 07, 2009
    Hi, I have the same exact problem for the same exact model. Prong broke and got stuck in the socket. Looking to order the part and replace it. Any advice appreciated.
  • mytwinkies Mar 10, 2009
    ...same problem, same model. Is this common?? I've never had this problem with any other products. Perhaps a manufacturing defect.
Ajkill
  • 2035 Answers
SOURCE: kenmore vacum wand power cord
Please click on this link:
http://www.geyservac.com/index.php/cPath/18/filter_id/12?osCsid=7f1b56cfc950368636c913a19a1e19b6
Good luck :
Posted on Jul 16, 2008
provactek
  • 17 Answers
SOURCE: belt broke, can't get bottom off
if it's the one in the picture then pop off the light cover by gently pushing in and prying on both sides . Remove the bulb by pushing and twisting , OK?, now see the 2 screws? take them out. now flip over the powerhead and gently pry at both sides toward the rear wheels.
Ta Daa!
Posted on Oct 02, 2008
SOURCE: Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Posted on Dec 10, 2008
  • 298 Answers
SOURCE: Kenmore Progressive Vacuum-Need to replace plug
Splice a new plug, but get a good one. Tough with a scew to hold it together
  • White wire goes on the silver terminal.
  • Black wire goes on the gold terminal.
  • Green (or bare ground) wire goes on the green terminal
More here:http://www.hammerzone.com/archives/elect/accessories/ext_cord/end1/replace.htm
Posted on Mar 26, 2009
SOURCE: Need to replace power cord and can't find how to open canister to replace
I had the same problem and could not find the other screws. You need to pry off the power cord retraction button, you will find two more screws under there. It's pretty easy after that!!!!
Posted on Mar 27, 2009
My kenmore progressive caniser needs a new power cord. the plug had one of the metal prongs break on the plug. how can I replace the cord? model 22812201
I do not know if you want to replace the replace the power cord or the receptacle for the power wand?
If you need the prong for the power cord you can purchase a replacement power plug from a local hardware store and it will function and look reasonable. If you want it to look like the original factory plug you can purchase the plug from the following link for $29.56 plus shipping.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=4370695&productGroupId=0020&supplierId=116&mv=rr
You could also purchase the cord and retractable reel if you want to make it easier for $53.38 plus shipping by clicking on the following link.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=8192087&productGroupId=0020&supplierId=116&mv=rr
Clicking on the links below will show the exploded parts view so you can see how to disassemble the unit to replace the cord.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0303013-00003.png
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0303013-00001.png
If you need the power wand plug click on the bellow link for $21.99 plus shipping.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=8175251&productGroupId=0020&supplierId=116&mv=rr
I hope this helps and is the information you needed.
Jun 22, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Beater bar lost power - even after pushing reset button
Hi There,
If you've already tried resetting the power brush, and it still won't come on, this indicates that your electrical hose has most likely gone bad, and needs to be replaced.
This is actually a pretty common problem on Panasonic canisters, as well as Kenmore canisters (Panasonic makes Kenmore canisters).
In order to confirm this, what you'll need to do is purchase a simple electrical tester from Home Depot, or Lowes, and test the hose to make sure you have power making it through the hose.
To test this, remove the hose from the wand so you just have the handle of the hose in your hand with nothing attached to it. Put both ends of the electrical tester into the two female receptacles that plug into the wand, turn the machine on, and make sure that your hose is set to the carpet setting.
You definitely should have power coming to the hose at this part. If there is no power getting her, this indicates that your hose has gone bad. You may also just purchase a new hose (see link below), and if for any reason this doesn't fix your problem, you may return the hose to us within 60 days for a full 100% refund.
If the hose does have power at the end of it, repeat the process with the wand attached to the hose, but not connected to the power nozzle. If you have power getting to the hose, but not the wand, this indicates your wand has gone bad and need to be replaced. If you have power to your wand and hose, this probably indicates that the cord in the neck of the power nozzle has gone bad. Inspect the wire in the neck of the nozzle and see if you see any burning, or discoloration in on the male prongs.
I'm pretty sure that you'll just need to replace the hose, this is by far the most common problem on Panasonic canisters.
There are two different styles of hoses for Panasonic canisters. In order to find out which one is yours, remove the hose from the canister itself. Where the hose cuff plugs into the canister portion, look at the electrical prongs. There is either a 2 prong hose, or 3 prong hose. Here are links to both of the hoses. If your hose is a 3 position hose with a setting for bare floors, and carpets, then you have the 3 prong hose.
3 Prong Panasonic Canister Electrical Hose (Most Common)
2 Prong Panasonic Canister Electrical Hose
If this didn't fix your problem, please just use the comment section on this repair page and let me know what the outcome was after testing it with the electrical tester, and I'll be more then happy to try and do some more advanced diagnosing with you.
I hope this was helpful to you. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me, this is really what keeps Fixya repair experts answering free questions, rather then just the premium questions that we get paid for. This is greatly appreciated.
Chris Jones
GoVacuum.com
May 07, 2010 | Panasonic MC-CG973 Canister Vacuum
How do I replace the electric cord for my Simplicity Shadow Vacuum cleaner model S13L? It's a canister cleaner.
Since the problem was with the plug on the electric cord, I replaced the plug, I cut the old plug, peel off the plastic cover on the cord, they were two wires, black & white, I purchased a new plug in a Home center, attach the wires to the new plug and it works just beautiful now, it was a two prong plug, which made it easier to fix.
Feb 16, 2010 | Simplicity Vacuums
Prong on one side of plug broken
You will need to get in touch with a Sears repair center and replace the cord and plug (they're one unit). If you do not have a local repair center, you can order the part online at searspartsdirect
http://www.searspartsdirect.com/partsdirect/index.action?psid=26128388&sid=PSx20071217x00001a&OVMTC=Exact&site=&creative=3106724154&OVKEY=sears%20parts
Jan 01, 2010 | Kenmore 23313 Whispertone Bagged Canister...
How do I open a Kenmore 116 Vacuum?
You shouldn't need to remove the cord just to put a new plug on. Just cut the end off about 2 inches back, strip the outer insulation and the wire ends and install the new plug. Make sure there are no stray strands of wire hanging out from under the screws. I always solder the ends, so that I am dealing with a solid wire rather than twisted strands.
Sep 19, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Mar 26, 2009 | Kenmore 25812 / 25813 Progressive Bagged...
Open power cord housing on kenmore 116 vac
You can go to the Sears Parts Direct website and type in your Model number. It will return both an exploded view and parts list, with pricing for replacement parts. You can also order from them, and they can tell you stock status as well.
Jan 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore vacum wand power cord
http://www.vacsew.com/vacuum-cleaners/kenmore-vacuum-parts.html/
Try here
Jul 16, 2008 | Vacuums
Jun 02, 2008 | Kenmore 22612 Bagged Canister Vacuum
Powerhead does not work and the light doesn't work. Canister does work
Some of these has a reset button to push on the powerhead. Check the plug at the end of the hose handle, is it pushed in, if you push on it and it goes further in, then the tube in the handle will have to be replaced, the holding tab broke off of the tube. Pull the wand off and look at the prongs to see if they are burnt. it they are, then that power cord will have to replace as well as the want.
Jan 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 22612 Bagged Canister Vacuum Logo
197 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
