Question about iLO Televison & Video
Need to turn external speakers on (ilo tv)
Have a Coby home theater system...need to hook up speakers...internal speakers on tv and external speakers will not work.What do I do?
  • 5 more comments
  • scanup404 Nov 12, 2008
    Coby
    Coby DVD-419 home theater system and the TV is iLo 32" flat panel
    yes , i connected the dvd player to my tv....but the speakers connect to the tv not the dvd player...the speakers have a red&white connector to them...i plugged this into the outlet on the front of my tv
    model #IWF2706....the dvd player has the red,white&yellow wires and they are connected to my tv...all of them...the subwoofer has a wire from it that has only two connectors wires ( red & White)..
    when i turned the dvd player on it works but the sound comes from the tv not my speakers that came with my home theater system...i hooked the wires from the subwoofer (red & white) to the back of my tv (audio in/out).. the speakers are not working,my tv speakers are working.
    thank you ....i will buy an audio cable and a splitter...if i have a problem may i contact you again..you are so helpful....hopefully i will be able to use this home theater system.. thanks again...sandi
  • Anonymous Mar 15, 2014
    turn off internal speakers enable external speakers sanyo dp37819
  • Anonymous Mar 19, 2014
    turn off internal speakers on vizio e500i but next time I turn on tv the speakers are on again. usining sony soundbar which defaults to standby until sees a sound signal from tv but tv defaults to internal speaker until it sees external speakers.
    Scholar:
  • 124 Answers
What is the model of the DVD player and the Television.
Posted on Nov 12, 2008
  • 2 more comments
  • Mike H. Nov 12, 2008
    if I am correct, your unit came with two speakers and a subwoofer correct?
    if so, do you have the speaker system connected to the DVD player?
    Thanks,
    Mike
    Ok, thanks, '
    You forget to give me one more information "What is the model of the DVD player and the Television." I need the television model number.
    The problem seems to come from, if you have the yellow wire connected to the Televesion, you have to make sure that the red and white wire is connected to the same input line as the yellow wire.
    Mike
    Ok so you have sound from the television and want the sound coming from the subwoofer speaker system as well. Well that is very easy. You will need to buy an a audio splitter. see image below
    and a audio cable, that consist of the red and white cable.
    http://tq-electronics.co.uk/images/Audio...">
    The splitter will be connected from the red and white cable from from the DVD player. DVD player.
    And the Audio cables will use one of the splitter connection for the TV and for the Subwoofer.
    You are very welcome to contact me Sandi.
    And just to brighten your day some more, You can contact me with warranty issue with your Coby product even if it is pass the warranty policy.
    Thanks,
    Mike
Trying to get my ps3, Emerson hd tv and coby DVD938 home theater all to work together
The DVD938 only has analog audio input (2.1 channel), thats why you have only a white (left channel) and red (right channel) audio connection from your ps3 to the home theatre. There is an option called PROLOGIC in the setup menu that will simulate 5.1 with the 2.1, it basically takes the 2.1 channels and splits it into all the speakers.
Mar 03, 2013 | Coby DVD938 Theater System
I have a samsung lcd tv that I am attempting to hook up a craig sound bar getting no sound out of external speaker
Check the settings on your tv. Many tv's need to have the internal speakers turned off in order for audio to be output from rear jacks.
Dec 31, 2012 | Craig Electronics CHT912 Bluetooth TV...
Hook up extion speaker to my coby tv it hook up to satlie tv
find R-out, L-out & connect to home theater R-in, L-in.
May 31, 2012 | Audio Players & Recorders
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
What outlets do I hook up to on the reciever and the tv for it to play on regular tv stations
Cable Box optical Digital Audio to Coby Digital Audio In. (This brings TV-related multi-channel and normal audio into the Coby so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the Coby on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
Mar 01, 2010 | Coby DVD938 Theater System
I can't get my philips 47pfl3603d/f7 to work with a coby dvd968 home theater system the tv has one spdif coaxial out and coby also has one i pluged the cable, still can't get to hear my tv channels thru...
You need to select the source of your home theater system. Press <SOURCE> on the home theater remote to switch between DVD, TUNER, and LINE modes. Select LINE, then you should now hear audio from your TV, Please make sure that your TV is not muted, just increase the volume until you hear audio on home theater. Also increase the volume of your home theater.
Regards,
Jeep Brainy
Jul 26, 2009 | Philips 47PFL3603D LCD TV
How do I hook up coby 5.1 300watt to my rca flat screen
audio out on the TV to audio in on the "home theatre system"
Feb 27, 2009 | Coby 5.1 Channel Home Theater Speaker...
Can't get surround sound for tv shows
The coby dvd 988 has 2 rca audio input jacks, you need to have these connected to your TV AUDIO OUT jacks, these are usually colored red and white like right and left stereo jacks, be sure to set up the TV for AUDIO output through these connections, some tv`s require that the internal built in speakers are cancelled and the audio output jacks are enabled. Set the coby input signal to receive the port you pluged the tv signal into.
Feb 06, 2009 | Coby DVD-988 Theater System
Am setting up a bose GSX 3-2-1 home theater
Need to know the TV connections. On newer TV's there RCA jack connection or ext speaker connections. Usually the external TV speaker connections hook to the woofer and the rest of the speakers are connected to the woofer. The woofer acts as the sound system for the rest of the speakers. With this method you need to mute the internal TV speakers by a swiich on the TV or internal TV setup menus and select ext speakers.
Jan 26, 2008 | Bose Cinemate Digital Home Theater System...
Ilo tv
i dont think that the ilo has a sound output port:(
Oct 17, 2007 | iLO V27DMBX Television
Televison & Video Logo
410 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
