Question about HP Office Equipment & Supplies
I have a HP LaserJet4L. It has suddenly started to print smudgy lines and stripes. The toner is two years old and is not an HP toner. Could the printer be nearing the end, I've had it 15 years and i'ts never had any problems before. I hope I just need a new toner. Thanks Urchin
  • HP Master
  • 4,338 Answers
It is probably the fuser unit that is causing the problem. Yes it would be better to purchase a new laserjet. They are very inexpensive, from $90. to $180.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 12, 2008
I have black smudgy lines going down the left hand side of my printed copies. What do I do?
1. Check the toner level, when it's low the quality of the prints becomes poor.
2. If toner level is good, clean out the printer inside. The best way is to buy an air compressed can, get the printer in an open space and blow any toner from the inside of the printer. Give it a good clean as there might be residual toner inside that make the poor quality.
Nov 29, 2010 | HP LaserJet P2015n Printer
Bad Printing and Stripes on Printed Sheets on HP 1100A
It isn't a fuzer problem it is most likly a image drum problem. To fix you have two choices replace the image drum with a oem part or a refurbished part or replace the printer. sometimes it is cheaper to get a replacement printer than to replace this part.
Dec 30, 2009 | HP LaserJet 1100 Printer
White stripe on right as if black toner needs
You probably got a piece of paper or something in the image path or the paper path. If it is a nice clean line it is more likely to be in the image path, if it is smudgy line it something may be scraping the toner off the paper before it gets to the fuser. Check the paper path.
Dec 26, 2009 | Dell 3010cn Laser Printer
HP 4200 printing very light, smudgy and blurry
Remove the rear door by pulling it down and squeezing the left tab to remove it.
Press the blue hooks and remove the fuser. Look for a worn coating on the gray roller.
Feb 19, 2009 | HP LaserJet 4200 Printer
Replaced toner is printing very light.
If the print quality is the same as the old one - light laser is dirty and/or transfer roller. Fuser would NEVER cause light copies -but rather, dark, smudgy copies
Jan 26, 2009 | HP LaserJet 4 plus Printer
Repeating wide smudgy horizintal line across my printed pages
I had the same problem, replaced the PCR in the cartridge, the small black drum that pre charges the drum and erase the old image.
After that print was all back ok.
Regards
Dec 11, 2008 | HP Q2613A OEM Genuine Black Laser Toner...
SMUDGE LINES
I'm gonna assume you have a laser printer. You might need a cleaning since some toner might have spilled when you replace your toner. Toner gets into the rollers inside the printer that pulls the paper thru and creates smudgy black lines.
Check out your local business supply store like Staples for Laser Printer Cleaning paper. It doesn't work 100% of the time depend how dirty the inside of the printer is. Maybe a quick fix then buying a new printer. Getting toner mess out is a a messy job.
Aug 21, 2008 | Sharp AM-400 Digital Multifunction Printer
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
55 people viewed this question
Ben Johnson
