Question about ViewSonic VP181s 18.1" LCD Monitor
LCD Monitor turns off or goes blank after a couple of seconds being on
LCD goes blank after a couple of seconds being on, the led is still green but its totally blank on the screen, the monitor doesn't turn off, cause you can still the that the LCD is still lit up but nothing is being displayed, I tried un installing the display adapter which is a GeForce 7100 GS but this hasn't worked, any suggestions?
  • 3 Answers
I too have an LCD Xerox - it worked fine for a while, then kept going blank. Unplugging and reconnecting from both pc and power seems to reset it. It hadn't happened for months but started again the other night when it occurred to me that I have downloaded MS security updates - I've removed the ones that I downloaded just before it started happening again and the problem seems to be solved. Hope this helps someone.
Posted on May 27, 2007
    President:
  • 2,961 Answers
An all too common problem with lcd's, you would think they would be more reliable after being on the market for years, alas they are not. See if it does the same thing on a friends PC if you are able; if so the you will know the lcd is faulty.
Posted on Nov 12, 2006
My monitor comes on and then goes off
Time for a new monitor. I have the same problem. Tried the monitor on three different PCs and it turns on for 2 seconds then goes blank, power stays on (green LED on power switch).
Temporary solution that worked for 1 day was to turn the brightness to 0 if you can manage to keep it on long enough to use the menu.
Jan 01, 2013 | Acer AL1916W 19" LCD Monitor
The screen goes blank after 1 second display, flicks back again to the display for 1 second and back to blank, this goes on non stop. The little led next to the on/off button goes from green to yellow...
pandres, Your monitor will need troubleshooting to find out reason why the 2 "cold-cathode-fluorescent-lamps" fail to remain lighted. They provide "white light" so you can see what is on the lcd panel. Connect a "known good" monitor to your pc to prove monitor is bad. If pc is ok, then your monitor will need repair. This type problem not new and is very common for all brands of ccfl back-lit lcd monitors. Watch some video clips at YOUTUBE that show disassembly and repair of ccfl lcd monitors. Read fixya profiles of "budmrtn" buddymc" "12fixlouie" for more information. 12fixlouie
Sep 08, 2010 | Neovo S 19 19 in. Flat Panel LCD Monitor
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Monitor comes on for a few seconds then goes blank.
Your looking at profesional repair. It could be DC/DC convertor, Monitor unit or PC/IF unit. (last two are expensive)
Jan 22, 2009 | Sharp LC-M3700P 37 in. HDTV-Ready LCD...
Philips 19s lcd monitor
you have to replace the capacitor in the high voltage board inside your lcd if you know how to open it
Nov 03, 2008 | Philips 190S7FS (Silver) 19 inch LCD...
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Sony SDM-HS53 Monitor Goes Blank
I used to have the same problem until I discovered that the cables in the back of the monitor weren't securely connected. I have a very similar model monitor to the one being displayed here
Apr 03, 2007 | Sony SDM-HS53 (Black) (Gray) 15" LCD...
ViewSonic VP181s 18.1" LCD Monitor Logo
280 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
