Question about Compaq Computers & Internet
Is there extra speaker jacks on the presario sr5605f besides the one for the monitor
  • Compaq Master
  • 4,338 Answers
Your PC has "Speakers: 6 speaker configurable", It has 6 outputs, which means that you can put a surround sound speaker set on it. You don't have to use the speakers from your monitor.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 12, 2008
How can i restart my compaq presario sr5605f desktop after it lost power during a restart repair cycle?
You may need to reload. Be sure to back up your data first. If the machine won't boot, and you have important files on it, you could purchase a USB Hard Drive Adaptor, pull out the hard drive, and copy any important files to another machine. Good luck.
Jul 06, 2014 | HP Compaq Presario SR5605F Desktop
How to reset compaq presario desktop computer
if the fans turn andl lights on motherboard proberly bad videocard .as i understand you got no picture.try new videocard.
Jan 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5605F...
New G215HL monitor connected to HP Compaq Presario harddrive - no sound. Previous monitor had a sound port, this one does not.
You need to connect an external set of speakers to the Audio output of the harddrive, as you put it. At the rear, or some other convenient place you should find a set of at least three, "Jacks" locate the "Green" output Jack, and use that to feed the powered speakers, you then will be able to hear sounds....
Sep 28, 2011 | Acer 22" X223w LCD Monitor
My Comoaq presario SR5605F has a black screen with the cursor intact. It happened right after I did a system restore. Can u give me a solution ?
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 15, 2011 | HP Compaq Presario SR5605F Desktop
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
My receiver has a single subwoofer line out. Will I get more or better base by using a Y cable so that I can connect to both left and right line in on my mirage mm-6 sub?
Your receiver delivers an unchanged power through its single line out jack. Therefore, if you use a Y cable to connect 2 speakers to that jack, the only thing you will get is to divide the power between the two speakers. Besides, I would not recommend this trick, as the nominal impedance would be strongly mismatched, putting in risk your system. The best solutuion seems to connect an extra amplifier to your receiver line out, and then connect extra speakers to that amplifier.
Sep 26, 2010 | Audio Players & Recorders
I am looking for a users manual for this computer and monitor
Hi! You can download the manual for this computer from the support website of hp.Its in pdf format, here is the link for the manual:http://tinyurl.com/ne9zkn...hope this helps...Cheers!!!
May 22, 2010 | HP Compaq Presario SR5605F Desktop
I'm frustrated. Love the picture on my Acer 22" monitor with speakers, but the sound is very poor. I have the volume for the computer turned up, but still can barely hear the sound. What can be done to...
Built-in monitor speakers are usually not the best quality. The monitor should have it's own volume control have you tried adjusting it?
You can use external speakers by plugging them into the same jack in the back (green) of the PC instead of the monitor.
Dec 12, 2008 | Acer V223WBD Monitor
I was given a 2003 Acer AL1916 monitor and came home and hooked it up to my old Compaq presario computer. The screen is fine but the audio is barely audible. I had speakers hooked to the side of my old...
The speakers are not supposed to plug into the monitor, they will plug into the speaker jack on the back of your computer (usually a green plug or it will have a picture of a speaker next to it)
Hope this helps
Good Luck!
Dec 09, 2008 | Acer AL1916W 19" LCD Monitor
No Sound through montior speakers
There should be a phono jack for the speakers to work. 1 lead from the back of you computer to the Normally back of the monitor but sometimes in the side. Check that also some monitors have separate power for the speakers check you have that.
Hope this is some help.
J
Dec 27, 2007 | Compaq Presario SR1000T (568657) PC...
Computers & Internet Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
