Question about Candy AQW130 Front Load Washer / Dryer
Candy aquaviva 1300 washer dryer
My washer dryer drains the water the drum is turning bit its not spinning the water of so the cloths are coming out soaking wet
SOURCE: Will not drain
Try cleaning the filter as when this gets all clogged up the water doesnt drain thru the pump
Posted on May 25, 2008
SOURCE: Not draining after cycle
Hi, there is a big pool of water after a wash cycle. I'm assuming it is a blockage in the filter. Where is the filter so that I check?
Cheers
Posted on Sep 13, 2008
I have a similar problem with my Candy WM801. However I cannot find the filter, it does not appear to be at the front... pulled it out and can't see anything obvious at the back either. Looking online for manuals, it should be simple shouldn't it!
Posted on Sep 23, 2008
SOURCE: my candy 514 is not draining properly - even after
I have a GE and my friend has the same problem with his whirlpool. Removed the frt cover adn looking at the washer on the left side there is a clean out drain. My kids leave things in pockets and filles this drain up and washer will not drain. it is very easy to do
Posted on Oct 26, 2009
Testimonial: "The drain thing was definitely clogged! Have cleared it and am mopping the mess up - will know if its worked in about 15 mins.."
  • 353 Answers
SOURCE: candy aquaviva plumbing
NO if it has two inlets then both are used buy a connector to connect both hoses together any diy shop will supply
Posted on Dec 21, 2009
HI THERE I have a candy aquaviva 800 washing machine and it seems to not want to drain all of a sudden, i have taken out the hose at the back and given a good wiggle and sat with it in a bucket while
Your drain pump is dead. Have a serviceman replace the pump. How old is the unit? If it's old enough that it has the old belt-driven style, have them check to see if the belt is stretched or broken.
Apr 30, 2012 | Washing Machines
I CANNOT FIND THE LINT TRAY/HOLDER ON MY CANDY AQUAVIVA 1300 WASHER DRYER. I FIND THE DRYER GIVES THE CLOTHES A DAMP SMELL WHEN DRIED. IS THIS DUE TO LINT BUILD UP?
This is usually located either near the bottom front, possibly behind a plate, or inside the rim of the drum. Check the user manual.
May 26, 2011 | Dryers
Candy aquaviva plumbing
Dec 20, 2009 | Washing Machines
My candy 514 is not draining properly - even after a spin cycle the clothes are still very wet suggesting that water is not getting out
Oct 26, 2009 | Candy CNW136 Front Load Washer/Dryer
Hoover Saver 1300 Washer Dryer - drum not emptying fully
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2009 | Washing Machines
My candy cmd 146 washer dryer
yes, 2 of them. front of the aly trunking on top of the drum. just press the little ceramic centers and it will work again, done mine 3 or 4 times now, bit annoying to be honest lol
Sep 11, 2008 | Candy CN146 Front Load Washer
Candy Aquaviva 1300 washing machine
fabrick condictioner drawer stays full can you help me bernie
May 21, 2008 | Candy AQW130 Front Load Washer / Dryer
Will not drain
Apr 24, 2008 | Candy AQ130 Front Load Washer
How to use the dryer of my Candy Aquaviva 1300 please?
wahing machine works great but a cant work out how to use dryer
Feb 21, 2008 | Candy AQ130 Front Load Washer
Candy AQW130 Front Load Washer / Dryer Logo
970 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
