Question about Scanport H21 21" LCD Display Monitor
Need power supply board for H21 LCD monitor
Can you tell me where I can find a company that sells the power supply circuit board for a H21 LCD Monitor. Model VT21F79.
The board has several numbers on it.
21F7B513
4143031400
Ver 0.06
VH31400 12.17 2004
I am hoping this is the problem. There is no power to the board, no light comes on for the power. I am using a known working outlet, power cord and video cable.
Thank you so much for your time.
Laura
H-21 scan port Dark Screen, If you unplug the green light flashes 2 or 3 times ending any activity until completely unpluged and plugged in again. My other scan port works fine using 1st monitor cables. I've used both ports on the graphics card. It's definately the monitor power supply or other componant.
Any ideas?
Bill
Posted on Nov 25, 2008
I've got a Scanport H21 monitor that the green light comes on but has a black screen. Can not dring up a menu or "VGA IN" message.
You can try a different cable for VGA. Check if the port is lose. The green light is only indicating a proper power supply to the monitor. The display is very much dependent on the VGA cable. If your monitor also has HDMI port, you can try to connect using that cable (provided the display adaptor also has HDMI port). If nothing works for you, take it to a hardware engineer or local repair shop.
Jan 20, 2014 | Scanport H21 21" LCD Display Monitor
I have an LG L1952HQ LCD monitor that shuts off every 5-10 sec. it's not the PC going into power saver or srceen saver mode
greatatuin1, Tell me the "date of manufacture" from rear of unit!! You may need to inspect the units power supply printed circuit board or black-brick switchmode power supply. Is power supply "lay on floor" type or internal to monitor case? Is your pc working ok with "differerent" monitor?? Have you been to youtube to watch "refurbishment" DIY videos of cold cathode-fluorescent-lamp back-lit lcd monitors??? If unit is really old and has lots and lots of "on" hours, you may even need to replace the CCFL lamps also. Tell me more info, so I can advise you. Symptom seems to be "black screen of death" !! Have you performed or even know the "flashlight test" that every ccfl lcd monitor owner should know??? Do additional comment back to me. 12fixlouie
Oct 24, 2010 | LG Computers & Internet
Ineed to buy power supply board 710 n
If you are looking for where to buy power board on your monitor, i will advice you go to any computer accessories shop around your locality to get the power board or you can order online from amazon.com.
Take care.
Aug 07, 2010 | Scanport H21 21" LCD Display Monitor
How cane get power supply
Most LCD monitor manufacturer do not make their own Power supply/Inverter board, you need to get the name and number of the board and search on line. You can also have more than one version of the power supply for the same model.
These people sell boards:
http://www.lcdparts.net/
http://www.lcdrepair.us
What is wrong with the board any way?
http://s807.photobucket.com/home/budm/allalbums
Apr 04, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
Flat screen will not turn on.
Hello David,
This is a classic symptom of a blown power supply board. If you open the monitor and look at the power supply board you will find parts called capacitors with bulging tops, they blow out because of trapped heat in the case. We have pictures on our web site at: www.ccl-la.com/capacitors.htm that will show you what to look for and what you need to get for the repair job. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. Youcan contact us at tech@ccl-la.com if you need any more information about the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 25, 2010 | Scanport H21 21" LCD Display Monitor
Won't power on. have to click the power on and off sevral times.
could be a faulty cap in the power supply usually the 470uf cause start up problems
Jan 05, 2010 | Scanport H21 21" LCD Display Monitor
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
H21 LCD Monitor -No display
With that many boards, it probably has a separate ballast (inverter) to run the lamps. In the power supply section, I would look for bulging electrolytics and bad connections. In the ballast I would suspect a shorted output transistor, a bad output transformer, a bulging capacitor or bad connections.
Jan 19, 2007 | Scanport N9 19" LCD Monitor
Open Questions:
Scanport H21 21" LCD Display Monitor Logo
602 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
richie46
ray gallant
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
