Question about Thomson Lyra PDP2335 (256 MB) MP3 Player
Problems playing mp3 songs in my thomson lyria pdp2335
First of all just say that I can listen to the radio with no problems but when I click to a mp3 song, it just skips it. the mp3 is not copyrighted, I have tried to format it, I have also tried with different bitrates... What shall I do?
0 characters
1 Points
Thomson mp3 model 6722 wont play songs after formatting drive
Preformat : By Fix-shad0w
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from or
Open up 'My Computer'. You should see it under the list of available drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Feb 21, 2010 | Thomson Lyra PDP2444 53 MB MP3 Player
I need a user manual for the phillips gogear vibe
no file for radio on my philips gogear.shows it has fm radio on to i if poss create a file for this?
Nov 20, 2009 | Philips GOGEAR SA6045 MP3 Player
I want to play music continuously in my Thomson Mp3 Lyra 1GB
all you have to do is highlight all the songs you want to play. then you right click and click on play. it will automaticlly play your songs
Apr 16, 2009 | MP3 & Digital Media Players
My M230 Sandisk is having problems with songs.
i can only put one song unless they are the same title but diffrent album name
Mar 21, 2009 | SanDisk Sansa m230 MP3 Player
Can u help me with my creative zen mp3 2 gb ?
It depends sometimes some songs may be copyrighted and cannot be played on the Mp3............ But as u say ur able to play 67 songs............ Just format your Mp3 player...... Formatting the Mp3 Player: Connect the Mp3 player to the Computer.......... Go to My Computer> Right click on the Removable Disk and click on Format and click on Start..... Know reload all the songs back to the Mp3 player..... Good Luck............
Dec 29, 2008 | Creative Labs Zen V MP3 Player
IRiver X20 scrambled sound on every song
i've recentlly had the same thing but mine fixes itself immediately after scrambling for 2 secs...
in your case though, if its just 1 song it could be the song codec. if otherwise then either try differnet headphones or maybe open it up and see if the headphone interface still works.
Nov 11, 2008 | iRiver X20 MP3 Player
Navagating music files on mp3 player
no, actually, you can't. it leaves off on the song you finished listening to after you turned it off. i know it's irritating, but you just get to listen to your songs in the order that you put them in.
Aug 09, 2008 | Coby MP-C883 MP3 Player
Thomson PDP2842 hangs
u may have a soft wear problem
Jan 14, 2008 | Thomson Lyra PDP2842U MP3 Player
I need help
MP3 players are very simple. What I do is go to a site called radio blog ( No inserting e-mail or anything. After getting the song I like (and loading it), I go to Tools>Internet Options>Settings>View Files then I choose the song I loaded, copy it onto the desktop and convert it (open as...) to a flash (.wav) and then drag it to the MP3 Player. It copies and bam, you're done.(Check it for viruses).Usually it is an .rbs format so I play it on flash, then save as and add .mp3 at the end. Also if the MP3 Player says a whole bunch of stuff you don't need(Audioslave%20-Be%20Yourself%20) select the song and click on properties and go the far right and click advanced and then artist and put in the artist and for title put the title of the song. If you did it right, it should play well. Hope it works
Jan 01, 2007 | Samsung YP-U1 MP3 Player
Thomson Lyra PDP2335 (256 MB) MP3 Player Logo
Top Thomson MP3 & Digital Media Players Experts
Are you a Thomson MP3 and Digital Media Player Expert? Answer questions, earn points and help others
