Question about Whirlpool GEW9250 Electric Dryer
Dryer is tripping the breaker
After eight years and no problems all of a sudden the dryer runs for about 20 minutes and then trips the breaker? I have vacuumed out the entire cavity. I also checked the exhaust and everything is clear. Can anyone help?
    New Friend:
I had the same problem and mine ending up being the red wire in the terminal block was sparking cause of frayed wires. Check your plug terminal box on the back of the dryer where the plug goes into the dryer and make sure all screws are tight and no wires are burning.
Posted on Jun 14, 2013
    Master:
  • 623 Answers
Well, if the burnt smell has a tinge of ozone to it, or a tinge of plastic,
(and because it's the only other answer) I'd think that the motor that is turning the dryer drum is the problem.
For some reason, the motor isn't turning fast enough, so it's lugging, that means it's pulling more current, which eventually trips the circuit breaker.
It could be something as simple as lint in the rollers that the dryer drum rolls on. It could also be that there is lint built up inside the motor and it's not getting air through. It could be that the motor's bearings need oil
(you have to be careful with the kind of lubrication, adding too much oil attracts dust and lint and can make the motor bind up worse than it did before oiling.
So- first, disconnect or slide to the side, the belt that connects the motor to the drum -
see if the drum spins/rolls freely- if not check the rollers for binding up with lint, or being worn down so much that the drum is off the tracks.
see if the motor spins freely - if not check the bearings for signs of lubrication- you don't normally use oil- in dusty environments, instead you use dry graphite lubricant that doesn't attract dust.
Also, see if the axle the motor spins on is loose- does it move back and forth in the plane 90 degrees to the rotation- if it does, that can mean the bearings are worn and it may be time for a new motor, or a bearing repair
(not incredibly difficult, appliance repair can do it, I'd guess the local bicycle shop could also)
Posted on Nov 13, 2008
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Whirlpool frontload dryer trips circuit when started all of the sudden. Gas dryer, replaced circuit, must be dryer
The dryer should be on a dedicated circuit. Is anything else on the same circuit? Try plugging the dryer into a different circuit and see if it still trips the breaker. The breaker trips because there is either a short or too much power is being drawn for the size of the circuit. Check how many amps the dryer uses, and make sure the circuit is rated for that load. If the dryer needs a 20 amp circuit, and the circuit it is plugged into is only a 15 amp circuit, that will trip the breaker.
If all that is good, there is a problem with the dryer, either a short or the motor is drawing too much power, which usually means it is at the end of it's useful life and need to be replaced. If you are handy, there are sites you can go to which will show how to remove the motor. There are appliance parts stores which will test your motor, and sell you a new one if you need one. I have a 30 year old dryer that still runs, with it's 4th motor and 5th belt, if you are handy. The cost of a repairman to come out is probably not worth it after the dryer is about 10 years old, better to replace the dryer at that point. The new ones are much more energy efficient and do a better job than the older equipment, so they are worth the investment.
Aug 02, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a samsung dryer dv218ae it runs but no heat can you help me
Your heater elements may be bad and need replacement. Is it an electric dryer? If so electric dryers run a dual breaker, this means 120 volts on one side of the breaker runs the motor, the other side of the breakers runs the heater coils. Its possible the heater side of the breaker has tripped. Try turning off the breaker for 20 seconds or so then reset. 220 volt breakers can trip on one side and not the other.
Sep 30, 2012 | Samsung DV218AEW Electric Dryer
Hello: I have a Maytag MDE9700AYM that was purchased three years ago but has been installed for less than one year. After the unit runs for 10-20 minutes, the circuit breakers trips off. Otherwise the...
It's possibly the circuit breaker rather than the dryer itself. Usually when it trips, it is overloaded or shorted. Overload can be a result of a loose connection or a bad heating element,when you remove the old breaker, see if it has some noticeable burn/corrosion marks where the wire is screwed down, I think replacing the breaker will fix the problem. Hope this helped Tim
Nov 07, 2010 | Maytag MDE9700AYM Electric Dryer
The dryer is causing the breaker to trip
check the entire venting system . possibly full of lint .
Dec 21, 2017 | Whirlpool LER4634J Electric Dryer
Circuit breaker trips after 10 minutes
could be a weak breaker,or poor high resistance connection from panel to dryer plug, then have someone check the current draw on the dryer while operating and see if it's within specs of the machine tag, if it's higher than that you may have a defective motor or heating element to case causing a higher than normal current draw
Nov 09, 2009 | Maytag PYE2300AY Electric Dryer
Seem to all of the sudden have problem when dryer gets warm the breaker trips? anyone know why that might be.dryer has been on the same outlet for 2 years.
Hi, When a breaker starts to trip on any appliance, it is drawing more amps then the unit is rated for. It should have a double pole 30 amp breaker if it is a 240 volt dryer.The first thing I would check would be the breaker and the 2 hot wires feeding it. Over the years, the wiring sometimes loosens up due to heat and they may be loose and just need to be tightened up. If you turn the breaker off, it kills the voltage to the wires going into it and you can then tighten them. If you are not comfortable doing this, maybe you know someone that can help you out.Also, overloading the dryer with a lot of cloths will cause the breaker to trip. I am sure that after 2 or more years that you are aware of this, just another cause.You may also have a problem in the motor, which draw a lot of amps if it over heats.You may have a lot of lint build-up around the motor and heating elements that should be cleaned out by removing the back of the dryer. Be sure the power is off before though. Try running the dryer with no cloths in it to see if the breaker still trips.If it still trips, I would say you are loosing the motor, but would check the breaker anyway. Please let me know what you find.
Sincerely, shastalaker7
Oct 31, 2009 | Dryers
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Tripping circuit breaker
if the dryer trips the breaker right away its a problem with the dryer if its after a while its the breaker. call an electrician to make sure the wires are secured tight to the breaker and the breaker is rated correctly. i can almost guarantee its the breaker.
Dec 18, 2006 | Kenmore Elite HE4 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
99 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
