Question about Kenmore 63942 Dryer
Will not start
Put timer for 60 mins,after 20mins it stoped and now it will not start again,should i just open the back panel and change the old timer.
    Problem Solver:
  • 5 Answers
First check door switch if it is gas also check non resetable fuse located in rear on blower housing
Posted on Nov 25, 2008
The dryer itself works fine, the timer goes too fast, if I set it to 150 mins it will be back at zero in about 10 mins probably less, this has only just started happening, I have always used 30-45 min
This is a mechanical timer that has an old fashioned timer spring inside. The spring is corroded or broken. If you want to save a buck, With the breaker supplying power turned off, Open the panel and look for an opening in the actual switch and, using the narrow tube that comes with CRC or WD40 spray and lubricate it. Then exercise the switch while the power is off. Second choice...order the part from the manufacturer!
Dec 28, 2012 | Dryers
Sputtering car, check engine flash
Stop using the car
You have serious cylinder misfires,so severe
you maybe ruining the exhaust converter,thus the smell
I won't write a book on all the causes or fixes,have a
repair shop diagnose
Dec 10, 2012 | Cars & Trucks
I have a 6 station orbit timer and I have problem with station 2 odd days coming on again after station 4 odd days the time is set to come on at 6 am and run for 60 min an10 min after it shuts off to start...
I am somewhat confused about your station numbers. How many stations do you have? What is Ihappening with stations 1, 3, 5, 6?
Regardless, this is probably what is happening.
No matter how many stations you have, YOU ONLY PUT IN ONE START TIME. That one start time begins the cycle that starts with station 1 and proceeds to the other stations based on your station RUN times.
If you have one start time of 6:00 am, and a run time of 60 minutes for each zone, then
At 6:00 am station 1 starts.
at 7:00, station 1 shuts off & station 2 starts.
at 8:00, station 2 shuts and station 3 starts, etc.
You are not programming the individual start times for each station.
If you put in more than one start time, the timer remembers and will run all stations then go back and begin again and if there is a third start time, it will begin a third time.
Gary
Sep 02, 2011 | Orbit 57882 9 Station Super Dial...
Put my washing on at a 60 degree wash for 1 hour 40 mins. Went back to machine several hours later, there was tiny amount of water on floor and machine had water in it but the wash had not progressed any...
Sounds like a blockage perhaps the filter needs cleaning or pump blades jammed...If its a Hotpoint then filter is middle of sump hose connected to the drum....
Jan 06, 2011 | Washing Machines
TIMER PROBLEM??? I have a Kenmore Elite Mod# 110.63932101. You can set the timer for 60 min's and watch it spin all the way down, beep & shut off in about 5 min's. Everything seems to be operating fine...
The operating thermostat controls the timer and should open and close the circuit as it senses heat during the dry cycle. If it fails to open it will just keep the timer 'energized all the time and run straight through and go off. Change the 'operating thermostat'
Jul 09, 2009 | Dryers
What is the formula to convert the time of 4:15 to 4.25 hours? I'm trying to add up the number of hours I do child care.
If you calculate 0.1hr as 6mins, you can get what you ask for.. This is just 1/10th of an hr.. to put it more easy, the time which you get, convert it into mins.. (1hr=60mins) and then divide by 60.. For eg:
3hrs = 180mins -> 180/60 = 3hrs
3hrs 20mins = 180+20mins -> 200/60 = 3.33hrs
4hrs 30mins = 240+30mins -> 270/60 = 45.hrs..
Simple math, isn't it??
Mar 20, 2009 | Microsoft Excel for PC
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Refigerator leaked water slightly then stoped cooling
Yes try to turn with a screw driver if possible. If it start working replace timer. If not it can be low on freon you would see frosting but no cooling.
Jan 07, 2008 | Magic Chef CTF2125 Top Freezer...
Maytag mav7600 agitator works and don't
Look at timer plug on harness for pins that are sticking out from side of timer plug, away from timer. See if they are all in the same amount. Sometimes one can work its way out so it won't make a good contact. Push in to plug if you find one.
Nov 14, 2007 | Maytag MAV7600 Top Load Washer
Kenmore 63942 Dryer Logo
44 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
