Indesit W103 On program 7 starts to work then controller just clicks round and round by itself.
  • johnuk2 Nov 28, 2008
    i have same prob but it stops at 4
I've found you need to reset the program cycle for this. It's annoying to lose the soap and conditioner but generally, if you download the manual and follow the reset instructions (which for me also involved turning the machine off at the mains aswell as holding the power button down with the machine on stop setting) it usually works ok.
Posted on Oct 14, 2009
Indesit w103 does not close at all, the door is broken, where can I find a spare part to change it?
Hi.
Go to ----WWW.4INDESIT.CO.UK/SPARES
You should be able to obtain the parts you require through this site.
Please leave feedback.
Thankyou.
Jan 06, 2010 | Indesit Washing Machines
Hi.I have a indesit washing machine model W103.It seems to run part way through it's cycle until it needs to drain.The program dial then starts clicking around.Someone suggested that it could be the belt??...
I would say, place a voltage tester on the pump motor wires and see if there is power to the pump. If there is, replace pump as it is defective.(very common problem). If not, your timer is unfortunately needing replacement. Let me know.(This is on the drain cycle when testing).
Oct 06, 2009 | Washing Machines
How to fit new door seal on Indesit W103 washing machine
this is not an easy job,go online and down load a copy of the machines manual even check out indesits web page.adrian
Feb 23, 2009 | Indesit W 123 Front Load Washer
Indesit w1 13 reset
If your washer has some black spots on timer dial then set your dial pointer to one of these spots to reset programme.
Then try it again, if it still does the same thing, then you probably have a faulty control module.
Expensive!!!!!
Nov 06, 2008 | Indesit WA 115 Front Load Washer
I have purchased a new door rubber seal(indesit W103) as the old one was split. i have removed the old one but cant work out how to put the new one on. It looks like theres a technique to it. please help
Fantastic walk-through, thank you! These instructions also work for the Indesit WIA111
Getting the seal back on is tricky - if you feel you have to really force in back on (like a tyre on a bike) then you are probably doing it wrong.
I found once I had the knack it was best to stasrt again in the least accessible place
Jul 30, 2008 | Indesit Washing Machines
My indesit washer/dryer model w10 ,is not working.the programme dial keeps cliking round wont start a programme or take in water.
probably a main module fault but worth while checking for continuity thro the heater and that the pump and filter are ok. the idea is that when a fault is detected, the dial will click round indicating a fault but usually it is the module itself. expensive part. not worth repair
Jul 04, 2008 | Indesit Washing Machines
No power - washing machine indesit w103
Start at the outlet
Did it trip a circuit breaker?
did a GFCI outlet Trip:?
or did it blow a fuse?
May 03, 2008 | Washing Machines
Program problems
please check you drain filter, situated @ bottm of appliance. if ok i think you may have a pcb fault and you need an engineer
Jul 14, 2007 | Indesit W 123 Front Load Washer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
190 people viewed this question
Top Washing Machines Experts
