Question about Tappan 30IN ELEC IGNa Oven
Glow plug on oven
Replaced glow plug igniter on oven. Does igniter stay on during the use of oven? never paid any attention before.
  • 1,543 Answers
Yes. Igniter stays on from just before ignition until just prior to burner shut down with each burn cycle.
Posted on Nov 12, 2008
What is a glow bar ignitor
Next to the burner in the oven sits a ceramic igniter. When you turn the oven it glows orange which ignites the flame. It stays on even if the oven is at temperature and the flame if off. There are 2 wires going to it and its connectors are in a part of the oven away from the heat and flame. They do burn out. There is no reset. You have to replace it.
Oct 30, 2017 | Ovens
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
Amp draw
Sounds like it is working as designed. Igniters should last fro several years but can crack at any time.
Apr 18, 2014 | Magic Chef Ovens
I smell gas when I turn on my oven. I replaced the gas line but have the same result.
Your Maytag wall oven is equipped with
pilotless ignition. Heat from the Glow Bar
ignitor lights the oven burner. With this type of
ignition system, the oven will not operate
during a power failure or if the wall oven is
disconnected from the wall outlet.
if it is plugged in and everything, your glow bar may be broken, which would mean you will either need to replace it, or get professional service.
Dec 25, 2010 | Maytag CWG3100A Gas Single Oven
I used the self clean and now the oven won't heat. The broiler still works.
Hi, The most likely problem is the igniter was damaged during the clean cycle. Take the floor out of the oven and the flame spreader. set the oven for 350. If the igniter does not glow turn the power off and pull the igniter out and check it with an ohms meter. If as I suspect it reads open you should replace it. If the igniter glows it still may be bad. The igniter should glow bright yellow to the point where you can't look at it. If it glows and uneven yellow/orange it's bad and again you should replace it. If you have any other questions please feel free to comment. Mike
Jan 03, 2010 | GE JGRP17 Gas Single Oven
Oven will not relight during cooking cycle
When the bake igniter becomes weak or burns out, your oven would not bake properly. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Oct 20, 2009 | Whirlpool SB160PEE Gas Single Oven
Glow plug comes on bright orange but does not ignite gas.
If the bake igniter glows bright grange and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
Oct 05, 2009 | Maytag CWG3100A Gas Single Oven
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Frigidaire Gas Oven
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition. You can get a replacement at an appliance parts store. If you have a friend or relative who is a heating/air conditioning repairperson they can test your current igniter. Good luck!
Jul 10, 2008 | Frigidaire FGB24L2A Gas Single Oven
Tappan 30IN ELEC IGNa Oven Logo
182 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Craig Butler
Craig Butler
Are you a Tappan Oven Expert? Answer questions, earn points and help others
