Question about Zanussi W1242W Front Load Washer
The fabric softener doesn't go in...
Hi there, my Zanussi washing machine works fine apart from the fact that it doesnt seem to dispense the fabric softener...it just stays in the compartment and the water doesn't seem to drain into it. Any thoughts?
  • Anonymous Mar 20, 2014
    water is not going through the fabric softener drawer
  • 641 Answers
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Aug 04, 2007
SOURCE:
Zanussi FLE1216w Repair Manual
Hi, my zanussi fle1216w is skipping the fabric softener stage of the cycle. I've cleaned the dispensing drawer and the surrounding areas, even put on a boil wash in case somethihg was gunge up or visits the Zanussi Owners Manual.
Mar 22, 2012 | Washing Machines
Fabric softener is not dispensing
drain tube stopped up with softener needs cleaning
Feb 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer
HI. your model has a dispenser solenoid for the fabric softener dispenser on this unit. If the solenoids are out or malfunctioning, it will render the dispenser useless. i recommend checking the solenoids on the fabric softener dispenser for continuity. The resistance should be 1100+- 7%. replacing this blown solenoid will fix this issue. Remember. the dispenser valve will not function without a working solenoid.
please rate and god bless.
Mar 22, 2009 | Frigidaire GLTF1670A Front Load Washer
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
How to pull apart fabric softener dispenser
MOST DON COME APPART SOME HAVE A BLUE RING PUT IT UP AND PULL THE SOFTERNER UP AND PUT IN THE WASHER RUN A LOUD SMALL AND HOT WATER AND LET IT CLEAN IT SELF IN THE WAHSER
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Problems with fabric softener
you either have low cold water pressure being caused by the screens on both ends of the cold waterline being clogged by sediment or one of the solinoids for the water inlet is bad. try removing cold water hose and cleaning both screens if that doesnt help youll need a solinoid
Nov 16, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Zanussi W1242W Front Load Washer Logo
239 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
