Question about HP DesignJet 5000 Printer
Check Printhead Cleaner Path error
Problem with hp 5000...need to calibrate...can't get to calibration menu...won't initalize
5 Suggested Answers
itdude4321
  • 13 Answers
SOURCE: Zebra S600 printer continues calibrating
The factory default settings for the S600 is to auto calibrate every time the printhead is closed and every time the power is cycled. If the media sensor is not positioned correctly for the media you are using the label size will not be detected during a calibration. You mentioned the media has no markings, doe sthe media have a space between the labels? If so, the media sensor may not see the gap in the labels adn therefor is not calibrating properly or not calibrating at all. Check the media sensor position. I have found that the media sensor must be at least 1" from the inner wall of the printer so it doesn't see the edge of the backing in oder to read the size of the labels.
Posted on Feb 02, 2008
SOURCE: Canon LBP-5000 Printer and Calibration
You have problem with one ot he (reffiled ?) toner.
Posted on Jul 28, 2008
reitann
  • 214 Answers
SOURCE: kodak aio 5100 all in one just prints red/pink
An inter active website is being provided by Kodak to help their customer w/ this issue.....Try using www.kodak.com/go/itg and use missing colors for sub class if this does'nt solve the issue call Tech. support. (1 800 421 6699)
Posted on Nov 14, 2008
smt24
  • 54 Answers
SOURCE: Problem with Printhead Path
Something (not sure what) is obstructing the movement of the carriage assembly. Turn off the power and remove the cleaners. Push the carriage assembly out and pull/push the belt to move the carriage assembly until you find the bind. If you've recently changed the belt or carriage assembly, make sure you properly adjusted the carriage height.
Posted on Jun 05, 2009
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
When copy, print scan a blank paper comes out...why? Replace new ink cartridges and tryied to callabrate...no success....at one time a Kodak services #F555951, and error code 3607 registered.
have you done the media sensor calibration? You can do this by press menu button on yoour printer then scroll down look for media sensor calibration., The purpose of media calibration is to detect the paper that you are using to your printer., MOst of the time do ing the calibration will solve issue., Now if you still encounter same problem ther might be a problem on the printer or on the pritnhead., You need to call kodak 1 800 421 6699, I think the printhead is free of charged you may request for printhead replacement
Nov 16, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5300 prints light or not at all color does better
to resolve the problem try to clean the printhead first, to clean the printhead just press on the menu button, select clean printhead, select deep clean.
After you clean the printhead try to re-calibrate the printhead, just go back to the menu the select calibrate printer then select print calibration page. Once you have the calibration sheet, place it on top of the scanner make sure that the blue arrow on the printout is pointing on the yellow arrow located on the top corner of the scanner glass then press on the start button to scan the calibration page. Once the calibration is complete try to make a test print, just go back to the menu then select print demosheet then press ok. If this will not correct the problem you need to call their technical support hotline
Aug 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I replaced the printer head but it won't calibrate
Press menu.
Press �� until Calibrate Printer is selected.
Press OK. A new screen appears with Print Calibration Page selected.
Press Start and follow the instructions on the LCD screen to complete the calibration.
If you want to clean them...
Press Menu to display the Main Menu.
Press �� until Clean Printhead is selected.
Press OK to go to the Clean Printhead menu.
Press OK to perform a Basic Clean.
Regards.
Apr 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How do I calibrate the printhead
you should et a message, if you dont push menu and look for printhead alignment or something like that
Jan 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Plotter needs recalibration
You need to enter the service calibrations menu, to do this select the set up menu, once inside the set up menu press the up arrow & enter keys together. This will take you to the service tools menu, from here select service calibrations (printhead alignment and colour calibration are both in this menu). If you still here problems after you have calibrated your machine or the calibration fail replace the printheads.
Oct 16, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
Will not print red
K...Trust the solution. Try these steps. Open the printer, remove the ink and remove the printhead (See User's guide). Reseat the printhead and the ink cartridges. The printer will come up with an error message that requires calibration. Do the calibration and scan the sheet that prints right after by pushing the start button. In the menu options, clean the printhead. Do one basic and one deep. Print a demo sheet (another menu option) to see if the quality has gotten better. If it has not call Kodak AiO Tech support. You will need a replacement printhead.
Jul 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Pictures
Apr 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer
HP DesignJet 5000 Printer Logo
230 people viewed this question
Ben Johnson
