Question about Dryers
Hotpoint dryer will not heat
I am not sure if I should replace the heater coil kit or the thermostat. I am also uncertain about the location of either part.
  • 135 Answers
Remove the plate at the back of the machine and the element will be revealed. Above it there are two thermal cutouts.Usually one or the other will be the cause of your problem. Take care when handling the element as they are very fragile these days.
Posted on Nov 12, 2008
Heating coil
No matter if u not findout the inside or outside coil then u can check by multimeter its positive or -ve points
Jun 09, 2013 | Hotpoint Aftermarket Clothes Dryer Heater...
I have a Hotpoint 7Kg TCM570 Aquarius tumble dryer and i have had it about a year. yesterday i put on a small load to dry and when i checked it when it was done and it was still wet when i put it on again...
Hello, Sorry. Your Hotpoint dryer needs a new heating element. See if there a panel that can be removed on the back of this cloths dryer, Some of these GE/Hotpoint will have their heating cartiage in the top of the drying machine, in back low down in the bottom, or the front cover will need to be remove. Before trying to tackle this simple job.....Please unplug tiyr dryer. SAFETY!
GB...stewbison
Sep 13, 2011 | Hotpoint Dryers
I have a hotpoint dryer and the problem that I`ve been having is my dryer just stops running and won`t start again until I reset the breaker box.Whats causing this?
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the blower motor to make sure it is not faulty, also check the blower fan blade to make sure it is not broken or plugged with lint.
Check the Door Switch.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
It's located on the blower housing.
It cannot be reset. A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Jan 15, 2011 | Hotpoint Dryers
Hotpoint ctd00 dryer only blowing cold air
Check your Wiring
replace it)
This is a FREE answer, Please rate me
Jan 05, 2011 | Hotpoint NWXR473EV Dryer
CREDA DRIER HEATING ELEMENT INTERMITANT, HAVE REPLACED ALONG WITH THERMOSTATS
Maybe an extra idea here...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
For video and pictures on how to replace the element go to the following website:
Dec 28, 2010 | Hotpoint Dryers
Will not heat
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
For further instructions on how to replace the element go to the following website:
Oct 06, 2010 | Hotpoint Dryers
The dryer spins and blows air... but the air is not hot... no matter the setting... Help... I'm a plumber... not a dryer!
Check your Wiring
Oct 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The Hotpoint Aquarius TDC32 dryer appears to keep working but does not heat up
this video will show you how to fix your dryers thermostats
You-Tube video "Vx9JMZRRKrg" placeholder (do not delete)
Nov 01, 2009 | Hotpoint TDC32 Electric Dryer
Is it possible for a reasonably competent DIY person to change the Dryer Heater Element on the Hotpoint Washer Dryer Model No WD420P
Yes if he/she has the proper tools and ability it will be possible for that person to change a heating element. If he/she decides to do so then the following instructions may help.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Oct 28, 2009 | Hotpoint Dryers
Hotpoint tdc 32 not heating up , replaced the two thermostats , worked for a couple of weeks now no heat again , thermostats are ok
Good Luck,
Hope this helps
Oct 26, 2009 | Hotpoint Dryers
Dryers Logo
75 people viewed this question
Top Dryers Experts
