Question about Bestec (ATX-250-12E) 250-Watt Power Supply
Problem with power supply atx-300-12eb3
When i try to turn on my pc, dont stay on the led just blink one time and never turn on and i note this: the fan from the power supply just spin one time also making a sound like is trying to turn on but it cant, i check the power supply and 2 capacitor have a bouble on top its that a signal of my power supply is damage?.
Ill apreciate your help thanks
  • Anonymous Mar 31, 2014
    can you help me with hp 620 power supply swicthing off after fan turns and cap lock blnk two times
  • 153 Answers
Faulty I should say, becaue you can repair it. Just replace the Buldgy capacitors. you'll need a soldering iron, soldering lead and a ****** to desolder the components terminals. Remember replace the caps with only the specific values indicated on them and also when replacing them see how you removed them is how you'll replace them and solder them back, if you not sure to do it yourself then provide the Capacitors and asked a friend who can do it for you. But if you think you can afford a new powersupply unit, thats fine.
Posted on Nov 13, 2008
  • 3 Answers
The 250series has been replaced with 300 or higher models. They had to much trouble with those.
However when I repaired the 250's not had any problems. One has worked two aditional years running 24/7
Posted on Jan 14, 2012
BST ATX - 250 - 12Z C7R it is a HP compaq 2290 microtower desktop..the power supply led just blinking...i tried the above procedures of unplugging and plugging of main power motherboard which only made the...
Does your motherboard have a beeper? Does it emit any distinguished beeps?
First, to locate the problem, try to boot your system with only a bare minimum of components: motherboard, cpu, ram, videocard. Try your system with a known to be good power supply. Then, if possible, try it with other known to be good components. If possible, check power supply with a psu tester or multimeter (that takes some time). Every bit of description of system behaviour will be helpful.
Feb 22, 2011 | Bestec (ATX-250-12E) 250-Watt Power Supply
Power supply led blinks but will not power up
My gateway was powered up and I came back into the room and it was not. It would not turn on so I checked the power supply with the paper clip jump method (which is the only thing I know how to do) and the green light along with the fan turns on. While it is plugged into the pc, it blinks with no fan running. The power supply is an ATX 300-12EB3. The Gateway is 556GE. Thank you for any help I can get on this.
Sep 23, 2010 | Gateway Bestec ATX-300-12EB3 305w Power...
Hp pavilion a430n power supply is blinking
Look at this photo
(http://www.atxpowersupplies.com/images/300-watt-atx-power-supply-FSP-ATX-300GU-350w.gif)
Did you connect the p4 atx 12vx1 plug?
You may also need to connect the aux x1 plug on some models.
Mar 08, 2010 | HP Pavilion a430n PC Desktop
My power supply is blinking green light and my PC has no power
plug your pc directly to your wall outlet and see if it turns on. If it works, then the problem is your power supply. If power supply has a reset button, press it and try again. If pc does not turn on when plugged to wall outlet, then power supply for pc may be out.
Feb 16, 2010 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Toshiba A75 - S209 Power LED Blinks non stop, no boot
Here are some troubleshooting steps. From your description, my impression is a bad motherboard.
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jan 13, 2010 | Computers & Internet
Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Aug 11, 2009 | Dell Dimension 2400 PC Desktop
Blinking power supply LED
Your power supply is fried. I had the same problem with my Bestec ATX 250 power supply. I fixed the problem by installing the StatTech model: ATXPOWER250. It was easy to install and works well. It is almost identical to the original but more quiet. I got it for $29 at MicroCenter.com. Also at online Newegg.com, Radioshack.com, Provantage.com, June 20,2009
Jun 07, 2009 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
ECS P4M800-M V 2.0 wont POST
may u have a grouded DVD drive, did u try another DVD or CD drive? may be it will help.....
Aug 14, 2008 | EliteGroup ECS P4M800-M Socket...
POWER
remove ram memory - it should beep when you switch it on - if no beep then check CPU in socket and cpu fan spinning when on.
Jul 31, 2008 | HP Compaq d530 SFF PC Desktop
Pc not starting
Sounds like a bad power supply. Although first I would check it over by unplugging Every Card, Hard Drive, even Memory, (mainly anything that is connected into the Motherboard), One at a time usually is best, as you may find a faulty card, or bus, run the Motherboard strictly off the Power Supply, If it then seems to run correctly, try pluggin just One thing back in at a time, (memory, then Hard Drive(s), then cards, Video-LAN-Modem-Sound/etc.
This should give you a good feel for what/or where about your system is failing.. Good luck, A good standard size Power Supply Unit nowadays is about 600W+, a lot of systems we get from the stores, or online will come with just 400W+,.
Again, Good Luck, and Happy Holidays!
Let me know how this works for you.
~G.
Nov 21, 2007 | Computers & Internet
Bestec (ATX-250-12E) 250-Watt Power Supply Logo
169 people viewed this question
Top Bestec Computers & Internet Experts
Allen Lightsey
Allen Lightsey
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
De ice
De ice
Are you a Bestec Computer and Internet Expert? Answer questions, earn points and help others
