Question about Home
Installation of shower panel -26345001
Took shower panel to South America and I am not to sure they know how to install it. Is there a manual or something I can email them with instructions?
  • 8,197 Answers
If i can get the make and model # I will look for the manual for you.
Posted on Apr 05, 2010
Nuvi2555LMT
The micro SD card has to be between 4-8gb. Garmin Express is used to load the South American maps. Garmin Express can be downloaded from Garmin. Once installed on your PC, plug your GPS into your PC. The program should give you the option to install the South American maps to the SD card.
Dec 31, 2016 | Garmin nuvi2555lmt nuvi 2555lmt
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
I can't find the fan resistor on my 2004 Mazda 3. Can someone help? I took the glove box out but do not see it. Also, there are no good service manuals for the 2004 Mazda 3 online! Thank you, Joe
This is for the blower motor resistor 04 Mazda 3 2.0
RESISTOR REMOVAL/INSTALLATION
  1. Disconnect the negative battery cable.
  2. Remove the two nuts securing the cooler hose (LO).
  3. Remove the following parts:
  1. Front doors
  2. Console
  3. Shift lever component.(MTX)
  4. Selector lever component (ATX)
  5. Decoration panel
  6. Front scuff plate
  7. Front side trim
  8. Glove compartment
  9. Shower ducts (LH, RH) (See A/C UNIT REMOVAL/INSTALLATION.)
  10. PASSENGER JUNCTION BOX (PJB)
  11. Car-navigation unit
  12. Lower panel
  13. Column cover
  14. Meter hood
  15. Instrument cluster
  16. Steering shaft (See STEERING WHEEL AND COLUMN REMOVAL/INSTALLATION.)
  17. A-pillar trim
  18. Center panel module
  19. LCD unit
  20. Windshield wiper arm and blade
  21. Cowl grille
  22. Cowl panel
  23. Windshield wiper motor
  1. Disconnect the air mix wire from the air mix link and wire clamp.
  2. Disconnect the airflow mode wire from the airflow mode main link and wire clamp.
  3. Disconnect the following connectors:
  • Blower motor connector
  • Evaporator temperature sensor connector
  • Air intake actuator connector
  • Resistor connector
  1. Remove the rear heat duct (1).
  2. Remove the heater case. (See A/C UNIT REMOVAL/INSTALLATION.)
  3. Remove the dashboard.
118941934
  1. Move the A/C unit to the right and remove the resistor.
CAUTION: While moving the A/C unit, do not apply excessive force. Otherwise it will result in deformation of the refrigerant piping or refrigerant gas leakage.
  1. Install in the reverse order of removal.
© 2015 ALLDATA LLC. All rights reserved. Terms and Conditions
Mar 10, 2015 | 2004 Mazda 3
What is the names of earths continents to day
By most standards, there are a seven continents - Africa, Antarctica, Asia, Australia, Europe, North America, and South America. Most students in the United States are taught that there are seven continents.
In Europe and other parts of the world, many students are taught of six continents, where North and South America are combined to form a single continent of America. Thus, these six continents are Africa, America, Antarctica, Asia, Australia, and Europe.
Mar 21, 2011 | Computers & Internet
Shower water pressure is dismal at best, girls cannot get soap out of hair, is there a way to adjust amount of water coming out of shower head, we have a delta monitor single valve assembly.
Yes, try changing the shower head and do not get one of those water saver heads...and even if you get a regular one take out the flow restrictor before installing it if it has one....it will be just inside the thread part and wil be a plastic or rubber piece with a small hole in it to slow down the water flow...
heatman101
Sep 08, 2010 | Delta & Single Handle Shower Faucet
Home Logo
277 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
