Question about MotorGuide Standard Motor Replacement Parts - Type: Switches And Compone
Have a motorguide foot control ''750 Classic'' 12/24 volt troller
Would like to know the age of this unit. Any info appreciated.
I have one that says manufactured in 1999.
Posted on Dec 11, 2008
I have a 2001 pro series 40 43 lbs motorguide troller and im not getting full power
Clean the terminals and the battery posts to get rid if stray grounding faults. Also check the connections inside the trolling motor where the cables come in to get rid of corrosion.
Aug 25, 2017 | Boating
My motorguide x15 trolling motorjust wants to spin around .. it has a remote foot control
Define 'wants to spin around'?
The propeller motor is supposed to spin around :>)
If the whole motor unit is spinning around you need to clamp the motor stem.
For factory support, you can get that from the website.
Xi5 Trolling Motor Xi5 Wireless Trolling Motor MotorGuide
Jul 19, 2016 | MotorGuide FW71 FB Freshwater Series...
I bought a used trolling motor (motorguide brute 750 50# thrust) it has a 12-24 volt selector switch and three wires to hook up to battery, a black, a white, and a red. i'm assuming on 12v setting of...
the black wire goes to - and the red goes to + for 12 volts. If you want 24 volts you need to add another battery and run a jumper wire from the - of the first battery to the + of the second battery and hook the white wire to the - of the second battery. Here is a picture to help you.
Mar 15, 2010 | MotorGuide Electrical Supplies
Can you change a motorguide 65lb thrust foot control model with fix speed settings to a variable speed
well a "Speed Controller" can usually be used on ANY DC/AC motor, depending on type, some motors just will not work, with a speed controller... Think of it a bit like a "Light Dimmer", with the "Bulb" being the "Motor"
Have a look below for info. www.stefanv.com/electronics/escprimer.html
Mar 05, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I HAVE A MOTORGUIDE MOTOR WITH THE FOLLOWING LABEL ON IT... "EP2.3HP" WITH SERIAL #SN 42663". LABEL ON TOP OF MOTOR IS "36 VOLT DIGITAL. VARIABLE SPEED". CANT FIND ANY INFO ON THIS MOTOR ANYWHERE? IT HAS...
I need the information off the tag motor frame volts amps and shaft type and I can tell you how to make it work. you didn't leave your e-mail address, also please rate. Thank you.
Aug 08, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide Standard Motor Replacement Parts  - Type: Switches And Compone Logo
941 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
