Question about Green Frog Art Old World Cradle
Green Frog Old World Replacement Hardware
I am currently expecting my second child and realized I lost the parts to the Green Frog Old World Cradle. I was wondering if anyone knew where I could get the pieces to replace them. Thank you!
Can I modify the handle bars on a Frog? I need to lower them for Mum under 5ft tall? Take then off and replace with adjustable handlebar? Which part would I need to purchase? Is it in stock? price?
The Cameleon has the adjustable handle it is not available as a part only as a complete chassis for around $400 Your Frog wheels, seat etc would fit. If you found a broken Cam frame on eBay you could swap the handles. Your Frog would have the parts required to fix the Cam. Click on this link to my tips section Note as you don't need the old Frog handle you could try prizing off and reusing the domes but I don't recommend that. Brake cable is compatible.
Aug 05, 2011 | Bugaboo Frog - Black Stroller
The screw to used to move the frog to adjust the throat is missing. Can I get a replacement? Is there another part of the adjustment assembly missing?
Auctions and search engines.
Some plane Mfgs. had custom threads made. Modern bolts and screws from the hardware store may not work. Take the plane to a genuine hardware store where someone will help.
There are typically 2 slotted machine screws that secure a frog to the plane.
The plane will work fine without the slotted frog adjustment screw near the brass thumb wheel.
Really old metal planes had no frog adjustment screws.
The new frog adjustment feature did boost sales though.
If the threaded bolt for the brass thumb wheel is missing it will need to be replaced so the cutter can be easily adjusted.
Jan 20, 2011 | Fulton Tools & Hardware - Others
Bugaboo of the seat harness clip broken
If you contact you will be able to purchase the replacement harness.
I hope this helps.
Nov 28, 2009 | Baby Gear
I have an Mitsubishi HD1080i series rptv, the tv is about 10 years old, yesterday as I was watching the World Series, my picture went to a pink glow and I seemed to of lost some of my color especially...
This may not be a picture tube problem, but considering the age of the unit it may be cold solder joints on or near the crt boards. Each tube has a CRT Board attached to the neck of each picture tube. Check these first for bad solder connections, in not then it may be the green tube has finally failed you. Getting tubes for this old of a unit will be very hard. IF it is the Tubes then i recommend you think about purchasing a newer set..
Nov 05, 2009 | Televison & Video
Child Design Crib Replacement Parts
I did the same thing I took the smallest side piece into my local do it yourself hardware store and the found the pieces for alot cheaper than the manufacture.
Jul 26, 2009 | Childesigns Shelby Crib
I need the instructions and screws
I can't find the instructions but they are simple to put together... As for hardware your local hardware store will have the screws you need... You may need to take the part in to get your thread right. If all else contact the manufacture and they may be willing to sell you the parts needed....
Oh and Congrats if you are/had another child
May 21, 2009 | Artist Colony Baby Gear
Green as a frog!!
ya take frog out lol jk did u cheak ic chips the cables mixed up ?
Jan 31, 2008 | LG 52SX4D 52" HDTV
Broken harness on bugaboo frog
PHONE: 1-800-460-2922
Jul 16, 2007 | Bugaboo Frog - Aubergine Stroller
Green Frog Art Old World Cradle Logo
62 people viewed this question
Top Green Frog Art Baby Gear Experts
Dorel UK
Dorel UK
Are you a Green Frog Art Baby Gear Expert? Answer questions, earn points and help others
